about an error
sir,
when i am doing 3d array initialization as following:
unsigned char keypad[4][4][0] =('0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F');
then its not showing any error.
but when i use following line:
unsigned char keypad[4][4][0] ={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
then compiler showing the error that there is some error near "{"
so can you please resolve my problem....?
  • PS circumventing a question seems a favorite tactic of yours
    I asked you a question and you reply with a totally unrelated question, I have no intention whatsoever answering your circumvention before you answer the original queation.
    you are very good at, (be proud at last you are good at something) instead of answering a question, throwing an unrelated question in and hanging on that as a showstopper although your throwing the unrelated question in was the original sidetracker.
    so bypassing your circumvention I repeat:
    A verbiage clarification request answered with an IF?
    get a post without a response to the question.
    so, homewrecker, ANSWER THE QUESTION and please give a link to a post, just one, where you have actually helped the OP rather than criticising other posts.
    if you can't do the above two, SHUT UP!!
  • "if you can't do the above two, SHUT UP!!
    Erik"
  • Request: Please add moderator interface with post and thread delete functions so we can clean up.
  • I( Erik) asked you a question and you reply with a totally unrelated question,
  • If it is an 8051 or a general debugging question, a certain someone is not too bad to engage with.
    On other topics where hairs are needlessly being split...
             |   PLEASE DO NOT   |            :.:\:\:/:/:.:
             |  FEED THE TROLLS  |           :=.' -   - '.=:
             |                   |           '=(\ 9   9 /)='
             |   Thank you,      |              (  (_)  )
             |       Management  |              /'-vvv-'\
                     |  |        @@@         /_//  /^\  \\_\
       @x@@x@        |  |         |/         WW(  (   )  )WW
       \||||/        |  |        \|           __\,,\ /,,/__
        \||/         |  |         |          (______Y______)
  • "On other topics where hairs are needlessly being split."
    Oops!
    s/hairs/hares/
    Splitting them is the most effective means of population control.
