how can i obtain the current values of registers like accumulator,B,stack pointer,PSW,DPTR,etc in C?? i am currently working on a trainer/development kit for 8051..One of the commands to be executed is R<CR> Once this command is executed,the values of all the registers like A,B,SP,PSW,DPH,DPL,R0,R1,R7 should be displayed on screen...how do i retrieve these register values in C?
"I'm not "zueisti"."
tammy, no one accused you of being zueisti.
and there are tons of things that you aren't and you don't need to enumerate them for us.
thank you.
"tammy, ..."
Ashley/qili/millwood/fdan00 ("f-dan", cute), you're not being transparent enough.
Bzzzzzt. Step up your game, change names, and try again.
Thanks for playing though.
http://www.keil.com/support/docs/601.htm
Why go through all the effort to do it in C, when you could do it in assembly so much faster.
Just inline the code in your C file, and treat it like a C function
