Hello All,
I am new to ARM. I am currently using LPC2378 (ARM7TDMI-S) processor on MCB2300 Keil Eval Board. I want to display A/D value on LCD. Kindly guide how to proceed step by step using C language. I don't have any exposure in Assembly language. However I am considerably good at C.
Regards
http://translate.google.be
You can translate Per's post and/or the user manual to your native language.
This has absolutely nothing to do with Keil, and is entirely a matter of the specific chip hardware.
If you need training on NXP products, you should contact your local NXP distributor...
Or, try the NXP forums?
Or, perhaps, get a consultant in to help you:
http://www.keil.com/condb
I beleive that NXP also maintain a Consultants list...
What the user manual very clearly tries to explain is that you can write-protect specific pins on the port.
I want to interface a DC motor on ARM7 board MCB2300 board. kindly guide.
What has that to do with this thread subject - reading A/D values from a potentiometer?
"What has that to do with this thread subject - reading A/D values from a potentiometer?"
Nothing at all!
"kindly guide"
Guidance:
1. Don't hijack unrelated threads.
2. Before You start your own thread, take some time to do some basic research; eg, www.lmgtfy.com
"Don't hijack unrelated threads."
But in this case it wasn't a hijack, but the OP who wanted to switch subject without starting a new thread.
