Hi everybody,
Could you please help me: i need to use an uart interrupt routine in a RTX code. I've already found some examples for the uart interrupt routine, but i cannot make it work using tasks. Has anybody an example to show me how to use it. Thanks
Thanks Per and Tamir,
I see your points and I think I probably should change some of my UART setups.
On another on of my setups I'm using a custom protocol where the data in one message could be larger than my buffer (in RAM). This is were I got to disabling the interrupt...
Basically my example was a little mis-leading because what I really do is use the receive interrupt as a start message interrupt and the task than polls for the rest of the message and processes as it receives the message (basically writes a large file to 'disk'. Because the processing is faster than the double-buffered receive I never really missed data.
But the problem with having the read task polling for the rest of the characters, is that the read task must have a high enough prio to poll the UART so you don't miss characters. But if the task busy-loops while polling, then it would starve lower-prio tasks.
A better way is to have a state machine, where read task consumes the number of characters that are available and then wait for more data and continue. So instead of polling by checking the UART directly, you poll by calling the RTOS wait function.
Polling by using a timer would also be "wrong", since that would still give a poll frequency that must be done faster than the maximum character receive speed but without guaranteeing that there is a character available on next poll. Keeping the interrupts enabled and using the RTOS wait function means the task only gets enabled after a timeout (if specified) or when there are one (or more) character available.
Hi everybody, i left this thread for a couple of days and i'm very pleased. I've learnd a lot of thing reading your posts. But i still have a problem with my code. I cannot receive anything from the Uart. I wrote a very simple code: i want to receive a character sended from Hyperterminal (it works, i'v already tested it), read it and managed it in a specific task which print it on the LCD. I'm using an STM32F103ZE. I've looked at many example and i'm quite sure that the code is right and i make some mistakes in the settings, i've putted a flag inside the UART interrupt handler but it is never set to 1. What should i check?
