Optimizing FIQ
I have SPI interrupt defined as FIQ and the execution time for it should be less than 12us, but adding a few checks and the execution time is going out of the limit. I've seen that it takes 2-3us for the ARM7TDMI to enter the FIQ.
Can you give some ideas how to optimize it to enter it quickly or execute quickly?
What should I use/avoid?
I realized I should avoid using % because it takes about 3us to compute a%100!
Any advice is welcome.
  • Having code in RAM was not the most safety solution, so my big switch was replaced by small functions for each state. Then I have a table with pointers to functions, and I have one variable pointing to the next state(as index of table). This way, the compiler isn't saving necessary registers for all the states every time, but it saves for each function if needed.
    This way the execution time is between 5us and 10us, which is much better.
    Writing the ISR in assembler is hard for me, and I suppose will be hard to maintain, so is not the preferred solution.
    And the compiler won't help me soon in the future, because Keil has not planned to fully support FIQ yet...
  • Only if you make it so!
    It's entirely up to you whether you implement it in such a way, and provide adequate documentation, to make it maintainable!
    But, of course, getting absolute maximum speed is almost always going to require "clever tricks" in the code - so the burden is on you to document them very clearly and completely.
  • "Having code in RAM was not the most safety solution"
    You mean, that a buggy software can overwrite this code? The same argument a can also say for your function pointers, I think.
    Sometimes there is no other way. Internal flash is full, code stored in NOR flash, but device access times are unacceptable. Scatter load to RAM, all is well.
  • It is not safe because of EMI. RAM is more vulnerable to EMI than Flash
  • If you really insist, code in RAM can be guarded by checksums just like data in RAM. Don't you think corrupt data in RAM can cause as much damage as corrupt code in RAM?
  • Code in RAM can definitely result in larger problems than data in RAM.
    With data in RAM, undamaged code can keep multiple copies and perform multiple evaluations to verify that the multiple computations give similar results.
    With code in RAM, the program may do just about anything. Code corruption will hopefully result in a trap after the program tries to access protected memory areas or gets an invalid opcode. But the only real protection from code corruption is to have multiple processors connected to some majority-vote hardware.
    But an important issue here is that the stack stores not just parameter data but also return pointers which is basically function pointers. So stack corruption can result in random code execution just as if processor instructions was stored in RAM. And it's impossible to use any checksumming to protect from stack corruption. We need microcontrollers with ECC-protected RAM if we really want to reduce the dangers from RAM corruption caused by EMI, radioactivity etc.
