error 65 at rdk_BLDC_Stellaris_Motor _Control_ Cortex-M3
Hi all!!!
How can I fix this problem?
*** error 65: access violation at 0x4002C000 : no 'read' permission
I think there are problems with QEI register ( Quadrature Encoder INcremental)
Compiling and Linking:
Build target 'basic-bldc'
compiling adc_ctrl.c...
compiling brake.c...
compiling hall_ctrl.c...
compiling main.c...
compiling pwm_ctrl.c...
compiling sine.c...
compiling sinemod.c...
compiling speed_sense.c...
assembling startup_rvmdk.S...
compiling trapmod.c...
compiling ui.c...
compiling ui_onboard.c...
linking...
Program Size: Code=10216 RO-data=360 RW-data=380 ZI-data=4116
User command #1: fromelf --bin --output .\rvmdk\basic-bldc.bin .\rvmdk\basic-bldc.axf
".\rvmdk\basic-bldc.axf" - 0 Error(s), 0 Warning(s).
Debugging and Running:
Running with Code Size Limit: 32K
Load "C:\\StellarisWare_BLDC\\boards\\rdk-bldc\\basic-bldc\\rvmdk\\basic-bldc.AXF"
*** Restricted Version with 32768 Byte Code Size Limit
*** Currently used: 10616 Bytes (32%)
*** error 65: access violation at 0x4002C014 : no 'read' permission
Code_fragment with problem ->>> 0x00001A18 4E6F LDR r6,[pc,#444] ; @0x00001BD8
230: ulNewTime = g_ulSpeedTime + HWREG(QEI0_BASE + QEI_O_TIME); 231: 232: // 233: // Compute the time between this edge and the previous edge. 234: //
0x00001A14 486F LDR r0,[pc,#444] ; @0x00001BD4
0x00001A16 6940 LDR r0,[r0,#0x14]
0x00001A18 4E6F LDR r6,[pc,#444] ; @0x00001BD8 // at this line is the running brake
0x00001A1A 68B1 LDR r1,[r6,#0x08]
0x00001A1C 4408 ADD r0,r0,r1
Thank You very much!!!
Cassani
0
