I am writing an I2C master transmitter object. The problem I am having is that the IRQ Handler for I2C1 is not firing. According to the manual, it should fire after the start condition is sent and the status register is 0x08. When I step through the code with the debugger, the status code is 0x08. I am using an MCB1700 development board. Why is it not firing? Did I not configure something properly? For tests, All I am doing is toggling an LED on when the interrupt fires. Once I solve this problem, I will write the rest of the code.
#include <stdio.h> #include <LPC17XX.h> #include "GPIO1Output.h" GPIO1Output out(P1_28); __irq void I2C1_IRQHandler(void) { if (LPC_I2C1->I2STAT == 0x08) { out.Set(); } } int main(void) { // Initialize I2C. LPC_PINCON->PINSEL0 = 0x0F; LPC_PINCON->PINMODE_OD0 = 0x03; NVIC_EnableIRQ(I2C1_IRQn); LPC_I2C1->I2CONSET = 0x40; LPC_I2C1->I2CONSET = 0x20; int status = LPC_I2C1->I2STAT; }
In your Difference Report->system_LPC17xx_c.htm
Left:
#define PLL0CFG_Val 0x0000000B
Right:
#define PLL0CFG_Val 0x00050063
As per your Difference Report, I believe that If you mix-up different versions of the [CMSIS style source], you will have some problems to fix.
There are also examples from NXP
I don't know, but I would not expect arbitrary files taken from NXP examples to "just work" with Keil examples - or vice-versa.
