USB-CDC
Hello all
I am Raju Kamal, a Student from University of offenburg, Germany. Now I am faceing a problem to implement the USB-CDC protocal by using MAX3420e interface with our Microprocessor.
Can any body send me the c source code for MAX3420e for USB-CDC.
It will be gratefull from me!!!
Best regards
Raju Kamal
  • First i would like to say sorry because of some miscommunication and some bad posting.
    Now whatever i have send is my code, some of them i have found from this forum and some from maxim. As well as i also need to change some to compatible with our compiler.
    So Now i am faceing a problem for writing by the usb.
    For my project i need to use the hyperterminal com. for coummincation i am using Docklight Scripting software. the final position is now if i send any data by the docklight or windows hyperterminal, it shows me transfer data but does not show receiving data.
    If it is still confuse please inform me i will try to explain it more.
  • my problem is now i can read but cannot write
    The above statements are very confusing to me.
    I don't know much about this, but normally, you should use an USB Analyzer to analyze what happens during the USB communication.
    A. USB Host to USB device -> OK. USB device to USB Host -> Failed.
    B. USB Host to USB device -> Failed. USB device to USB Host -> OK.
    Your problem is A or B?
    How do you know/confirm that, it is OK/Failed?
    Did you put a breakpoint at the beginning of the USB ISR to see what happens?
  • Does anybody get the idea what is the problem??
    My communication between PC (host) to usb is ok but USB to PC (host) is not ok.
    For CDC shall i need to use the endpoint2 for Output?
    The last function "void USB_writeln2" use for writing. here i use Endpoint2, is it ok? i also check with other Endpoint but its remain same no improvement.
  • "A. USB Host to USB device -> OK.
    Your problem is A or B?"
    My problem is A. My "USB device to USB host is not ok".
    I have checked with USB analyzer and found USB Host to USB device is ok but the other direction is not ok!!
    I have also used some break point for debugging.
    can you tell me how can do the "bulk transfer". So far i understand there is a interrupt transfer and bulk transfer. i need to know about the bulk transfer.
    If it is still confuse i can write my testing procedure in details.
  • I don't know much about USB/USBCDC. And I am not familiar with your MCU and your USB solution (Library/Source Code).
    But I think/guess that, for most USBCDC device, the Data Flow for sending data from Device to Host (Bulk-In) is:
    1. Host polls Device regularly.
    2. The USB ISR of the device handles such a polling. (USB frame interrupt handler)
    3. The USB ISR of the device puts data into Bulk-In EP. (USB frame interrupt handler)
    4. When Bulk-In EP finishes the data sending, another interrupt triggered. (Interrupt driven data sending)
    5. The USB ISR of the device handles the next Bulk-In. (USB Bulk-In interrupt handler) It puts more data into Bulk-In EP. (Go to Step 4)
    With the USB Analyzer, did you see some regular IN-Packets? How did you respond to such a IN-Packet?
  • -> With the USB Analyzer, did you see some regular IN-Packets? How did you respond to such a IN-Packet? <-
    The above question is incorrect.
    It should be:
    With the USB Analyzer, did you see some regular IN-NAKs?
  • With the USB Analyzer, could you see your Endpoint Descriptor of the Bulk-In EP?
  • Now i can get the both way communication by changing in the Endpoint descriptor on "bmAttributes". But faceing a new problem:
    During writing in the usb getting extra constant value. for example: i want to write on usb "12345".
    then i get "X.2345". This "X." all the time comes and "1" is missing.
    This problem i am faceing for anykind of string, Missing first charcter and giving "X." instead of First character.
  • Did you put a breakpoint at where the program starts to get the string?
