initialiazation of arm
Dear All,
I am working my project of led Blinking.The controller used is arm7 LPC2214.Crystal is 11.0592mhz.
Which works fine but only one problem is, to make it working i have to touch one of my Oscilloscope probe to crystal of controller.Then it start working.Also works well in keil debugger(internal) and on proteus.So please help me to solve this problem.
The source code is as follows,
#include <lpc22xx.h>
#include <stdio.h>
#define VREF  3
#define Beep      0x00001000
#define LED1      0x00000800
#define LED2      0x00000400
#define LED3      0x00000200
#define LED4      0x00000100
#define CE                0x00000001
#define OE                0x00000002
#define WE                0x08000000
#define low   IO0CLR = LED1 ;   \
              IO0CLR = LED2 ;   \
              IO0CLR = Beep ;
#define hig   IO0SET  = LED1 ;   \
              IO0SET  = LED2 ;   \
              IO0SET  = Beep ;
unsigned int val;
unsigned long Fosc = 11059200;
unsigned long Fcclk = 0;
unsigned long Fcco = 0;
unsigned long Fpclk = 0 ;
        void TargetResetInit(void)
        Fcclk = Fosc * 4;
                Fcco = Fcclk * 4;
                Fpclk = (Fcclk / 4) * 1  ;
                MEMMAP = 0x2;                   //remap
            PLLCON = 3;
                if ((Fpclk / (Fcclk / 4)) == 1)
                VPBDIV = 0x10;
                else if ((Fpclk / (Fcclk / 4))== 2)
                                VPBDIV = 0x11;
                         else if ((Fpclk / (Fcclk / 4)) ==  4)
                                        VPBDIV = 1;
                if ((Fcco / Fcclk) == 2)
                PLLCFG = ((Fcclk / Fosc) - 1) | (0 << 5);
                else if ((Fcco / Fcclk) == 4)
                PLLCFG = ((Fcclk / Fosc) - 1) | (1 << 5);
                else if ((Fcco / Fcclk) == 8)
                PLLCFG = ((Fcclk / Fosc) - 1) | (2 << 5);
                else if ((Fcco / Fcclk) == 16)
                PLLCFG = ((Fcclk / Fosc) - 1) | (3 << 5);
                PLLFEED = 0xaa;
        PLLFEED = 0x55;
        while((PLLSTAT & (1 << 10)) == 0);
        PLLCON = 3;
        PLLFEED = 0xaa;
        PLLFEED = 0x55;
            MAMCR = 0;
                if( Fcclk < 20000000)
                MAMTIM = 1;
                else
                if ( Fcclk < 40000000)
                MAMTIM = 2;
                else
                MAMTIM = 3;
            MAMCR = 2;
                VICIntEnClr = 0xffffffff;
        VICVectAddr = 0;
        VICIntSelect = 0;
void Delay (unsigned long a) {
  while (--a!=0);
 void ledInit(void)
   IO2DIR = 0xFFFFFFFF;
   IO2SET = 0;
   IO1PIN = 0x00000000;
   IO1DIR |= CE;
   IO1DIR |= OE;
   IODIR1 |= CE;
   IODIR1 |= OE;
   IO1SET |= CE;
   IO1SET |= OE;
   IO3DIR = 0xFFFFFFFF;
   IO3SET = WE;
   IO0DIR = LED1;
   IO0SET |= LED1;
static void ledOn(int led){
   IO0CLR = led;
static void ledOff(int led){
   IO0SET = led;
void delay(int d){
  for(; d; --d);
   int main(void)
          ledInit();
          TargetResetInit();
      ledOn(LED2);
          ledInit();
           while(1)
        ledOn(LED1);
        delay(20000*8);
        delay(20000*8);
        delay(20000*8);
        delay(20000*8);
        delay(20000*8);
        ledOff(LED1);
                delay(20000*8);
        delay(20000*8);
        delay(20000*8);
        delay(20000*8);
        delay(20000*8);
Thanks & regards,
Girish
  • Hi,
    Thanks for your kind Co-operation,
    Yes i posted two codes .First is sample code of led blinking. Other is i made as given in user manual.
    My senior is not embedded professional is Analog Expert. So i can not ask my queries to him.
    Other thing is the board which i am working is old board and is customized from other party.
    So i am only having the circuit diagram and a sample code. Which is based on ucosII and no other details. So i cant get more help from my resources.
    On power up initiate the PLL frequency which is on 11 Mhz. is anything else required ?
    Thanks & Regards
    Girish.
  • "So i can not ask my queries to him"
    Nonsense!
    Even if he's not a microcontroller expert, he should be able to help you with the basic hardware debugging to find why your oscillator's not working; in fact, an Analogue expert would be an excellent choice to help with oscillator problems - as that is, essentially, an analogue problem!
    And, anyhow, the act of explaining to someone else is often a great way to help yourself; see, for example, www.8052.com/.../96775
    and: www.8052.com/.../100837
    Again, someone who is actually there with you, looking at your actual hardware, seeing the actual results of your tests, speaking your language, who knows you, knows your project, etc, etc is at a great advantage over any remote stranger on a forum!
    Even if he isn't an expert in the field.
    "the board which i am working is old board and is customized from other party"
    So you have to consider the possibility that it is broken.
  • Dear Sir,
    As you suggested i discussed with our senior,He took following actions,
    Changed Crystal,
    Change Capacitor across it (used 33pf ,old was 20p) ,
    Resistor of 1 Mega Ohm used across crystal,
    Grounded Body of crystal by wire,
    Comes to result that there is something wrong in initialization of Crystal/PLL in
    Program.
    Because i am getting same result as before,
    I have to touch the Oscilloscope probe to Crystal out Pin.Then it starts working.
    One thing i want to point out is ,My crystal Frequency is 11.0592 Mhz. And the frequency which is out from XCLk Pin is 44Mhz which is calculated from formula.
    Fcclk = Fosc * 4;
    Fcco = Fcclk * 4;
    Fpclk = Fcclk / 4 * 1;
    given user manual.
    So can you suggest any change or give proper initialization code for PLL.
    Please.
    Thanks & regards,
    Girish
  • But have you realized that the startup of the crystal is not the same as the initialization of the PLL.
    If your processor is similar to the LPC23xx chips then:
    - Enable main oscillator.
    - Wait for main oscillator to stabilize.
    - Select the clock source for the PLL.
    - Wait for the PLL to stabilize.
    - Setup clock dividers.
    - Switch to PLL clock.
    Your posted code covers only some of these steps - and getting the oscillator to start is separate from having the PLL produce a core clock frequency.
    Strictly speaking, the processor does not have any "please I want you to spin up exactly as much as this".
    But it isn't unlikely that your processor contains a similar setting as the LPC23xx have, to select which oscillator range to use. The 23xx have a driver optimization setting to know if the oscillator crystal is 1..20MHz or if it is above. An error in this setting would obviously be a good way for the oscillator to have a hard time spinning up.
    However - as already noted in this post and previous posts: You have not posted any code for turning on the oscillator. We just don't know. We have only seen the irrelevant code where you play with the PLL.
  • Dear sir,
    enable main Oscillator
    #ifdef __DEBUG
                            _WDWORD(0xE01FC080, 0x00000001); // PLLCON
                            _WDWORD(0xE01FC08C, 0x000000AA); // PLLFEED
                            _WDWORD(0xE01FC08C, 0x00000055); // PLLFEED
                            // Disable PLL
                            _WDWORD(0xE01FC080, 0x00000000); // PLLCON
                            _sleep_ (100); // Wait for PLL disable
                            _WDWORD(0xE01FC10C, 0x00000001); // CLKSRCSEL: main osc
                            _WDWORD(0xE01FC1A0, 0x00000020); // SCS: Enable main osc
                            _sleep_ (100); // Wait for osc to stabilize
                            //_WDWORD(0xE01FC084, 0x0000000E); // PLLCFG for 12mhz->60mhz
                            _sleep_ (1000); // Wait
            #endif
    Thanks & regards,
    Girish
  • "Changed Crystal,
    Grounded Body of crystal by wire,"
    User manual for LPC2214 does not specify any resistor if a fundamental crystal is used. Do you use a fundamental crystal, or overtone crystal?
    Requirement for a fundamental crystal is also that Cp is <= 7pF - does your crystal fulfill this?
    You mention old capacitors was 20p and now is 30p - but without mentioning crystal load capacitance or series reistance. So are the capacitors correct according to the table in the processor user manual, for the given frequency range and load capacitance?
    It isn't clear from your posts if your reset signal is asserted for at least 10ms after power-on.
    Your posted code contains:
    1 - Why magic numbers instead of labeling the registers. Is it funny to read code containing 0xE01FC10C?
    2 - You say you have LPC2214 - but it doesn't seem to have any CLKSRCSEL register or any register at address 0xE01FC10C. It is available on LPC23xx (and maybe other families).
    3 - You say you have LPC2214, and sets bit 0x20 in SCS. But that bit doesn't seem to be defined. It is OSCEN on LPC23xx (and maybe other families).
    Are you doing cut-and-paste programming from whatever sources you find all over the net? Or does the following sentence not only mix up milli/Mega for crystal frequency, but also used processor:
    "The controller used is arm7 LPC2214.Crystal is 11.0592mhz."
  • Hi,
    As i said in my last post, yes i used numbers because the lpc 2214 controller doesn’t have register like CLKSRCSEL like you have in 23x or 21x series, also not have the definition for it in lpc2214.h header file and in startup’s file. As you said to enable the main oscillator i used code which is given in keil website. Which is not explained in detailed in user manual . So it was not clear for me also about Enabling the main oscillator. And about sentence "The controller used is arm7 LPC2214.Crystal is 11.0592mhz." it is for explanation in short for my controller and peripheral. And about me i worked on lpc2148 also working on embedded systems from last 4 years. But first time i faced such situation where not much choice for major change in hardware as old code is well running & proven. So write post for my difficulties and problem. It is clear that there is issue initialization code for oscillator. But struggling to sort it out.
    So i request you to Please help me to sort it out,
    Thanks in advance,
    Girish
