Hi guys, I am using keil C51 to do the program and debugging the cypress FX2 ezusb chip. In my project options I selected Cypress FX2 as the device type. Should I add an include file in my .a51 file? Also, if I need to add one instruction at location 0043h, how do I do it? I tried CSEG 0043h, keil says syntax error. I am new to both cypress fx2 and keil.
There you go: it has already been established in the other thread that he won't use 'C' - so that was a waste of time suggesting it!
Not at all. After a while he'll succumb to the superliminal messages and convert to a life of 'C'.
If I get a bit more evangelical he might even cash in his worldly posessions and make a contribution towards the cost of my next Rolls Royce.
"a life of 'C'" would be a sad life.
No I am not in any way saying that the OP should not have 'C' in his toolchest, but a good life would be "a life of 'C' and assembler"
I tried $include "fx2regs.h" I get the file not found error. Anyone know where to add the header files. I added them to C:\Keil\C51\INC\ and also my project folder. I still get the error.
That just gives a file name, doesn't it?
It doesn't give any information as to the location of that file, does it?
So the assembler will obviously have to apply some default location (or set of locations) in which to look, won't it?
And the place to find out about what that default (or set of defaults) is will, obviously, be the assembler's Manual...
There is nothing special or magic about include files; Including a file is exactly equivalent to having just typed its contents verbatim into the source file.
Therefore you never have to use an include file - but it may often be more convenient to do so...
I will move on to C eventually. For the time being my plan is to do USB HID with the cypress chip in Assembly. As soon as I finish that, I am gonna move on to C. My previous USB HID project was done with the MAX3420 and FPGA (picoblaze) in assembly.
I know there is nothing magical about include files. But they make life convenient and code looks much nicer.
So what was the question?
