hello sir/madam , i am doing project on serial communication between pc and 89c52.all the connections are correct. but the problem is with the receiving of the data in the hyperterminal. when i press some letters in hypeterminal some other letter will be displayed; i am not getting what is the and where is the fault.. could you suggest me some solutions.. thanking you
i also don't change the code randomly..
I have a feeling that is "shital madam" would tell you to, you would...
dear Tamir Michael i am not getting why this is so.. (being an expert(hope so!))instead of giving steps to solve a problem you are replying something non sense...if you know the solution then give.. if you don know then..i think you can sit quite...
I don't understand why you refuse to really do what has been proposed to you (you are not alone, alas). Throughly read the user manual. Comment your code. All of it. Verify hardware settings on all parties involved. Test. Fly. Buy. Bye.
The steps have been given, and the first is to ensure that you fully understand the code that you have to start with!
An excellent way to ensure that you fully understand the code is to go through it carefully and comment what it is doing.
Once you fully understand the existing code, then - and only then - you can move on to modifying it...
I think you are displaying the characters which you have typed from keypad.(if not then tell me what actually you want to do?)
The first thing you need to do, then,... Andy Neil ...is to go through that code and provide comments that describe what you think it is supposed to be doing! Andy is SO right!
OMG! That was in true Code Monkey violation. Time to put the monkey down: Euthasol with a touch of Phenytoin should do the trick.
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
Dear friend, I’m using ATMEL 89c52 using 11.059MHz how to calculate delay in this routine? DELAY: mov temp1,#19h lp1: mov temp2,#19h lp2: nop djnz temp2, lp2 djnz temp1, lp1 ret
Dear friends I’m using ATMEL 89c52 using 11.059MHz how to calculate delay in this routine? DELAY:mov temp1,#19h lp1:mov temp2,#19h lp2:nop djnz temp2, lp2 djnz temp1, lp1 ret
... problem in serial communication between pc and 89c52, I might have answered.
1) for new subject start new thread 2) format the code (no tabs) and follow the "Tips for Posting Messages .... Place source code" above the reply window.
