Avoid using Keil 4.13a - it generates defective code
I warn anybody before using ARM Keil 4.13a. It generates defective code. I have spent several hours with debugging a code that has been already worked. The problem affects local variables of functions and passing arguments. Code has been wrongly compiled without any optimization. I have no courage and time to test optimizations.
I also encourage Keil not to publish Keil 4.13a any more.
Keil 4.12 seems to be OK.
  • I think I can second this. I am also having problems with pointers and passing arguments.
    Look at this GIF animation:
    http://bleyer.org/keil/ptr.gif
    The "usbPackBufRx" function receives a "PackBuf" object through the "buf" pointer. It gets the actual object through a FIFO call, and the address value is, correctly, 0x2000_014C.
    After that I call the "processBuf" function with "buf" as its argument. However inside that function, the buffer pointer value is passed as 0x0000_0000.
    Also, the debugger is giving me some weird information in the Locals window. For example, some return value shows as 0x4C (byte) although it should be zero (int).
    I wonder if Keil has proper regression tests when releasing new versions of the compiler. Any decent C test suite should have been able to catch this.
    I hope we have a fix soon. I will revert back to 4.12.
    Cheers.
  • Oops - I guess this happens when you are working on a Sunday @ 1AM.
    On preparing my bug report to Kiel, I spotted an extra '&' that was killing my code. The funny thing is that also messed up the Locals window. Go figure.
    Cheers.
  • It has already been pointed out that there are known issues with the Debugger...
