Hi there,
I am using an own PCB with Luminary lm3s8962 (based on the evaluation board) with LabVIEW for ARM and KEIL uVision V3.85
In the past I've been developing code to, Log some data to/Read logfiles from, a microSD card without problems.
The data that is being logged is become a little bit more and at this moment I get corrupted data on/from the microSD card. I am using SanDisk 2 GB microSD's.
problem one: When I write enough data for a longer time I see that sometimes the data is wrong. I tested this behavior and I can reproduce it. The data size is OK but where I expect data like: 112;112;112;112;112;112 I see: 112;112;11;111;1112;112
sometimes the SDcard copies old or wrong data to that position that is wrong.
I've made a change which decrease the buffer per write. Now I don't see this problem anymore. Is this an known issue?
problem two: When I read files from the microSD card on my embedded ARM and read the data via USB, I get wrong data (the first bytes are looking like a directory table of FAT) I didn't made any change to the USB Read protocol and I wipe the microSD before every test.
When I read the microSD card in Windows, there are no problems. Is there someone that is also getting strange behavior like this?
I don't think it's strange at all:
When stuff "works" sometimes, and fails others, timing is always a prime suspect!
Was that a released version of FS_CM3.lib, if so what version.
Thanks Darren
I had the one that comes with LabVIEW for ARM 2010 -> RL-ARM V3.70
I have now RL-ARM V4.11, build myself but not changed the source
Thanks for the update..
sorry, in my previous post I meant LabVIEW for ARM 2009..
