Problem with GSM switch and 89c51
I have to make this project for my school but i can't make it run. I've problems with message extraction and with the interrupt. Please help.
This is my code
#include <reg51.h>
#include <string.h>
sbit Water=P2^0;
sbit Window=P2^1;
//declarations
void clear(void);
void tx0(unsigned char);
void delay_sms (unsigned int);
void SMSString(char*text) ;
void init();
void read_text(unsigned char * , unsigned char * , unsigned char *);
unsigned char j,abc;
unsigned char idata msg1[150];
unsigned char rec_no[20];
unsigned char time_date[20];
unsigned char choice=0;
unsigned char idata tmp10[16];
void serial () interrupt 4
msg1[abc]=SBUF;
abc++;
RI=0;
void main (void)
clear();
init();
Window=0;
Water=0;
SMSString("AT\r"); // AT commands to initialize gsm modem
delay_sms(1000);
SMSString( "ATe0\r"); // turn off echo
delay_sms(1000);
SMSString( "AT&W\r"); // save settings
delay_sms(1000);
SMSString( "AT+CMGF=1\r"); // select text mode for sms
delay_sms(1000);
SMSString( "AT+CNMI=2,1,0,0,0\r"); // notification of new sms
delay_sms(1000);
SMSString( "AT+CMGR=1\r"); // AT command to read sms
delay_sms(1000);
do
IE=0X90;   // Enable serial interrupt
delay_sms(1000);
// i get a response like this
// +CMGR: "REC UNREAD","+3069********",,"11/04/09,11:26:48+12"
// Window on
// OK
// I think that's the format the 8051 get +CMTI: "SM",1\r+CMGR: "REC UNREAD","+306982037789",,"11/04/09,11:26:48+12"\rStatus\n\rOK\r
// read sms and store in buffer msg1
read_text(msg1,rec_no,time_date);
if(strncmp("Water on",msg1,8)==0)
Water=1;
strncpy(tmp10,"Water   Window  ",16);
tmp10[6]=Water;
tmp10[15]=Window;
SMSString("AT+CMGS=\"");
SMSString(rec_no);
SMSString("\"+<CR>");
delay_sms(1000);
SMSString(tmp10);
SMSString("\n\r");
delay_sms(1000);
else  if(strncmp("Water off",msg1,9)==0)
Water=0;
tmp10[6]=Water;
tmp10[15]=Window;
SMSString(rec_no);
delay_sms(1000);
SMSString(tmp10);
SMSString("\n\r");
delay_sms(1000);
else  if(strncmp("Window on",msg1,9)==0)
Window=1;
tmp10[6]=Water;
tmp10[15]=Window;
SMSString(rec_no);
delay_sms(1000);
SMSString(tmp10);
SMSString("\n\r");
delay_sms(1000);
else  if(strncmp("Window off",msg1,10)==0)
Window=0;
tmp10[6]=Water;
tmp10[15]=Window;
SMSString(rec_no);
delay_sms(1000);
SMSString(tmp10);
SMSString("\n\r");
delay_sms(1000);
else  if(strncmp("Status",msg1,6)==0)
tmp10[6]=Water;
tmp10[15]=Window;
SMSString(rec_no);
delay_sms(1000);
SMSString(tmp10);
SMSString("\n\r");
delay_sms(1000);
else
SMSString(rec_no);
SMSString("\"+<CR>\r");
delay_sms(1000);
SMSString("Wrong Command");
SMSString("\n\r");
delay_sms(1000);
SMSString(rec_no);
delay_sms(1000);
SMSString(msg1);
delay_sms(1000);
SMSString("AT+CMGD=1\r");
delay_sms(1000);
IE=0X00;   // Disable serial interrupt
delay_sms(1000);
while(1);
void init(void)
j=0;
abc=0;
TL1=0XFD; //9600 @ 11.0592
TH1=0xFD;
TMOD=0x20;
SCON=0x50;
TR1=1;
void SMSString(unsigned char* text) //function to send SMS using GSM modem
while (*text)
tx0(*text++);
void tx0(unsigned char x) //send data to serial port 0
EA=0;
SBUF=x;
while(TI==0);
TI=0;
EA=1;
void delay_sms (unsigned int count)
unsigned int i;
    while(count) {
        i = 115;
                while(i>0) i--;
        count--;
void read_text( unsigned char *msg,unsigned char *no ,unsigned char *time)
unsigned char *temp;
temp=msg;
do
msg++;
while(*msg!='+');
do
msg++;
while(*msg!='+');
do
msg++;
while(*msg!='+');         //  reaching number
do
*no++=*msg++;
while(*msg!='"');         // reaching time
*no++='\0';
msg++;
msg++;
msg++;
do
*time++=*msg++;
while(*msg!='"');         // reaching message
*time='\0';
do
msg++;
while(*msg!='\r');
msg++;
do
*temp++=*msg++;
while(*msg!='\n');       // reaching the end of message
*temp='\0';
void clear(void)
unsigned char a;
for(a=0;a<100;a++)
msg1[a]=0x00;
  • I modified my braces and changed the serial interrupt but there is still a lot work to be done.
    #include <reg51.h>
    #include <string.h>
    #include <stdio.h>
    sbit Water=P2^0;
    sbit Window=P2^1;
    //declarations
    void clear(void);
    void init();
    void Status();
    void init_modem();
    void process_modem_character(unsigned char *);
    unsigned char idata phone[15];               // Store received phone number
    unsigned char idata msg1[100];               // Store received message
    unsigned char j,bufcounter;
    void serial () interrupt 4 using 1
        if (RI)
            while(!RI)
                    RI=0;
                    if(bufcounter<100)
                    msg1[bufcounter++]=SBUF;
    void main (void)
            clear();
            init();
            init_modem();
            do
                            delay_sms(1000);
                    // Window on
                    // OK
                    // \+CMTI\: \"SM\",1\r+CMGR: \"REC UNREAD\"\,\"+3069********\"\,\,\"11\/04\/09\,11\:26\:48\+12\"\rStatus\n\rOK\r
                            process_modem_character(msg1);    // read sms and store it
                                    Water=1;
                                    Status();
                                    Water=0;
                                    Status();
                                    Window=1;
                                    Status();
                                    Window=0;
                                    Status();
                                    Status();
                            else
                            SMSString(phone);
                            SMSString("\"\n\r");
                            delay_sms(1000);
                            SMSString("\n\r");
                            delay_sms(1000);
                    delay_sms(1000);
                    delay_sms(1000);
            while(1);
    void init(void)
            j=0;
            bufcounter=0;
            TH1=0xFD;
            TMOD=0x20;
            SCON=0x50;
            TR1=1;
            while (*text)
                    tx0(*text++);
            EA=0;
            SBUF=x;
            while(TI==0);
            TI=0;
            EA=1;
            unsigned int i;
        while(count)
           i = 115;
           while(i>0) i--;
           count--;
    void init_modem(void)
            Window=0;
            Water=0;
            delay_sms(1000);
            delay_sms(1000);
            delay_sms(1000);
            delay_sms(1000);
            delay_sms(1000);
            delay_sms(1000);
    void Status(void)
            unsigned char tmp10 = sprintf(msg1 ,"Water is %s and Window is %s\n" , Water, Window);
            SMSString(phone);
            SMSString("\"\n");
            delay_sms(1000);
            //SMSString(tmp10);
            SMSString("\n\r");
            delay_sms(1000);
    enum States
        STATE_IDLE,
        STATE_FIND_CMT,
        STATE_CMT_GET_NUMBER,
        STATE_CMT_GET_COMMA,
        STATE_CMT_GET_MSG_START,
        STATE_CMT_GET_MSG,
    state = STATE_IDLE;
    const unsigned char* pattern;
    int ch;
    void process_modem_character(unsigned char*msg) {
        switch (state) {
            case STATE_IDLE:
                if (msg == '+')
                    state = STATE_FIND_CMT;
                    pattern = "\+CMTI\: \"SM\",1\r+CMGR: \"REC UNREAD\"\,\"";
                break;
            case STATE_FIND_CMT:
                if (*pattern != msg)
                    state = STATE_IDLE;
                            else
                    pattern++;
                    if (*pattern == '\0')
                        state = STATE_CMT_GET_NUMBER;
                        ch = 0;
                break;
            case STATE_CMT_GET_NUMBER:
                if (msg == '\"')
                    state = STATE_CMT_GET_COMMA;
                            else if (ch >= sizeof(phone))
                    // Too long phone number :(
                    state = STATE_IDLE;
                            else
                                    ch++;
                    phone[ch] = *msg;
                    phone[ch] = '\0';
                break;
            case STATE_CMT_GET_COMMA:
                if (msg == ' ')
                    ;    // Ignore white space
                            else if (msg == ',')
                    state = STATE_CMT_GET_MSG_START;
                            else
                    // Invalid character received
                    state = STATE_IDLE;
                break;
            default:
                // Invalid state.
                state = STATE_IDLE;
        } // switch
    } // process_modem_character
    void clear(void)
            unsigned char a;
            for(a=0;a<100;a++)
            msg1[a]=0x00;
  • Also i get error C214: illegal pointer conversion
    void Status(void)
            SMSString(phone);
            SMSString("\"\n");
            delay_sms(1000);
            SMSString(tmp10);
            SMSString("\n\r");
            delay_sms(1000);
    and i don't really understand why.
  • Stop writing random noise and try to think about everything you write.
    tmp10 is a character. Do SMSString expect a character? Doesn't it expect a pointer to one or more characters?
    Water and Window are bits. So why do you think %s is good formatting parameters for the sprintf() call? Don't you think bits have some form of integer values? %s is used to print strings, not integers.
    Don't post questions as soon as you get stuck. Read the manual. Make sure you have understood the relevant sections in it. Post questions if you can't understand a specific part of the manual or you think you have fulfilled the requirements given in the manual but still get errors. But do not post questions for every compilation error you get or you will never get done with this assignment.
