I'm building my project via the command line using something like this:
"C:\Program Files\Keil\UV4\Uv4.exe" -b ".\myProj.uvproj"
The problem is that this command does not send anything to the stdout. The only option I see is to output the results to a file, using the -o option. Is there any way of just showing the results in the same command prompt window without resorting to some ugly hack?
Also, is there any way to perform a clean on a project via the command line?
Hans-Bernhard,
The problem is that there is no functional export method of the GUI project file that will work for a full build from a source repository. Thus, one must use the UV4.exe command line, which still doesn't export the compilation result data that is output by the compiler to the stdout and/or stderr streams that can be monitored by an automated build utility.
UV4 is not the center of the universe. Being a good citizen in the tool world goes a long way.
If I have to create make files from scratch, that have to be maintained by the developer, then the value of the IDE is dramatically reduced. There are other IDE's that provide similar utility and cost a lot less.
It does output them to a file though, which is trivially easy to package shoot out through stdout later, if you have your heart so strictly set on doing it that way. So no problem at all.
Hans-Bernhard, That's a poor excuse for a production build process.
I misunderstood what the "*.__i" files are. They are compiler line inputs for each source file. I've never seen that arrangement for a build process. Quite unconventional. I thought they were some sort of intermediate file. My bad.
The batch file system does not return a non-zero value on error. As Per Westermark mentioned, one must write a tool that parses the "*.bat" files and generate new files (Ant XML, Makefile, etc.) so that return codes are checked, at a minimum. More complete would be to parse the "*.d", "*.__i", "*._ia", "*.lnp", and "*.bat" files into new build scripts (for the build tool of your choice.)
