ARM RTOS help required urgent
hello friends
i have written the code for ARM RTOS, i have used same priority for all of my 4 task, its working fine
my problem is when i change the priority in the code then all task's are not executing simultaneously....
please any one help
  • What is your goal? To have four tasks because your teacher have said that you should implement a program using an RTOS and containing 4 tasks. Or do you want four tasks because you have made an analysis of the problem and figured out that you have four different actions that needs to run concurrently in different combinations?
    If additional tasks doesn't simplify the design then you either do something wrong or have a program that doesn't need tasks in the first place.
  • i should implement the program containing 4 task...
    i have 4 different external modules
    1. BUZZER - To turn ON and OFF continuously
    2. ADC() - To read the POT value and Display it on the LCD
    3. SPI() - To send some sequences to LED PATTERNS continuously
    4. SCI() - sending POT value again to the hyper terminal using SCI protocol
  • But the buzzer doesn't sound like it have any reason at all to know anything about any other thread. It sounds like a thread that should sleep until another thread (anyone) does send an event: Please sound buzzer. Then it should either sound the buzzer for a fixed time, or until it gets an event "shut up". After that, it should start waiting again for an event to sound.
    Or are your buzzer thread really intended to decide on the beeping itself? In that case, it doesn't need any events at all. It can just turn on - wait - turn off - wait - repeat.
    The ADC should run continuously - it really shouldn't matter if the buzzer is on or off. But since you don't want to consume all CPU capacity for this, you either have to time slice the processor with other tasks of same priority or the ADC task must regularly sleep - sleep length depending on number of ADC updates/second.
    The SPI thread shouldn't care about any ADC or buzzer - unless the LED patterns should change depending on ADC value or if the buzzer sounds or not. So just a loop that does what it should and either sleeps to reserve time for other threads or round-robin-schedules with similarly prioritized threads.
    Not sure what POT values are. Meaning potentiometer values? As in values read in by the ADC thread? And what is the SCI protocol? Anyway - still a task that can run regularly either with round-robin scheduling or intentional delays to get x number of values sent every second.
    Why don't you play with the examples Keil installs with the compiler? They clearly shows how to use the OS functions.
  • In this program SCI() function will Read the ADC(POT) value(of the same ADC) and displays on the Hyper terminal
  • per,
    i am sorry.........
    i m not understanding this
    www.keil.com/.../rlarm_os_evt_wait_or.htm
    function................
    i have the example code . i am not able to understand please help
    example code:
    /* PROJECT NAME: Events                                         */
    /* Project:      Introduction to RL-ARM                     */
    /* Engineer:     T Martin        tmartin@hitex.co.uk        */
    /* Filename:     main.c                                     */
    /* Language:     C                                              */
    /* Compiler:     Real View 3.4                                      */
    /* Assembler:                                                               */
    /* O/S:                 RL-ARM 3.4                                  */
    /* COPYRIGHT: Hitex UK Ltd              2007                                            */
    /* LICENSE:   THIS VERSION CREATED FOR FREE DISTRIBUTION        */
    /* Function:                                                */
    /* Example        */
    /* Demonstrates the handeling of event flags in RTL RTOS        */
    /* Oscillator frequency 12.000 Mhz                                                      */
    /* Target board Keil MCB23000                                                           */
    #include <rtl.h>
    #include <LPC23xx.H>
    #include "LCD.h"
    void LED_Init(void);
    void LED_On (unsigned int num);
    void LED_Off (unsigned int num);
    void task1 (void);        // Function prototypes for tasks
    void task2 (void);
    void task3 (void);
    void task4 (void);
    OS_TID tsk1,tsk2,tsk3,tsk4;                                                             //Define Task-ID variables
    int main (void)
    LED_Init();
    lcd_init();        //Setup the LCD display
    lcd_clear();
    lcd_print ("  Event  ");
    os_sys_init (task1);        //Start the RTX with task1
    __task void task1 (void)        //define function as task
    tsk1            = os_tsk_self();                                                        //Get Task 1 Handle
    tsk2            = os_tsk_create(task2,1);                                       //create tasks
    tsk3            = os_tsk_create(task3,1);
    tsk4            = os_tsk_create(task4,1);
    while(1)
    os_evt_wait_or(0x0005,0xffff);                                                  //Wait for an event to be set, no time out
    set_cursor (0, 1);        //Print running task to LCD
    lcd_print ("  Task 1      ");
    LED_On(0x01);        //Switch on an LED to how the task has run
    os_dly_wait(50);
    os_evt_set(0x0001,tsk2);        //Set an event for task 2. Each task has 16 event flags
    os_evt_set(0x0001,tsk3);        //Set an event in task 3
    __task void task2 (void)
    while(1)
    os_evt_wait_or(0x0001,0xffff);                                                  //Wait for an event
    lcd_print ("  Task 2      ");
    LED_On(0x02);        //Switch on an LED to how the task has run
    os_dly_wait(50);
    os_evt_set(0x0002,tsk3);        //Set an event in Task 3
    __task void task3 (void)
    while(1)
    os_evt_wait_and(0x0003,0xffff);                                                 // Wait for two event flags to be set
    lcd_print ("  Task 3      ");
    LED_On(0x04);        //Switch on an LED to how the task has run
    os_dly_wait(50);
    LED_Off(0x07);        //Clear the led's
    os_dly_wait(100);        //Delay
    os_evt_set(0x0001,tsk1);        //Trigger task 1 to start over
    __task void task4 (void)
    os_evt_set(0x0001,tsk1);        //Set an event in task 1 to kick off with
    os_tsk_delete_self();        //Delete the task
     void LED_Init(void)
      PINSEL10 = 0;                                                         // Disable ETM interface, enable LEDs
      FIO2DIR  = 0x000000FF;                                                // P2.0..7 defined as Outputs
      FIO2MASK = 0x00000000;
        // Function that turns on requested LED
      FIO2SET |=  num;
        // Function that turns off requested LED
      FIO2CLR |= num;
  • ABSTRACT:
    This example demonstrates the use of event flags to trigger execution of tasks
    The project consists of four tasks
    tasks 1 -3 wait for one of their event flags to be set
    task four sets the event flag of task1 and then deletes itself
    task 1 switches on led 1 and then sets the event flag of task two
    task two switches on led two and sets the event flag of task three
    task 3 switches on LED three waits for a period then switches off all LEDs
    and then sets the event flag of task one and the sequence restarts.
    in the above he used event flags as 5,1,3, for each task, what are these events? how the event flag will set?
  • Everything (basically) is explained by the return value of the function (as described in the manual):
    OS_R_EVT At least one of the flags specified by wait_flags has been set.
    OS_R_TMO The timeout has expired.
    So a task may wait for flag 1 or flag 2 or flag 3 or flag 4 or flag 5 or ... and will wake when one or more of the flags it waits for (the reason it has an "or" in the name, as in event 1 _or_ event 2 _or_ event 3 ...) gets set, or after a timeout, i.e. having waited too long without anyone setting one of the event flags.
    So how to set an event? Don't you think the function os_evt_set(flags,task) does that? Why else would the function be named "evt" and "set"?
    The events are nothing more than flags. You decide what each flag stands for. The OS doesn't care. You may decide that bit 0 is "one more beer please" while bit 1 is "please self-destroy". So if you have 16 flags, then you can signal up ti 16 different events and the receiving task can decide which of these 16 events it is interested in servicing.
    Alas, that school project is quite meaningless since it doesn't contain any concurrency. It's just a state machine that could have been implemented in a single task like:
    for (;;) {
        do_task1();
        do_task2();
        do_task3();
    But alas, not all teachers do give meaningful exercises. It would have been so very much better if one of the tasks had continued doing what it was expected to do, while it requested another task to perform a different job concurrently and then signal back when that other job was done.
  • Thank you per
    if i set the flag 1 in task1 , it means that i should wait for that perticular flag(flag 1) in task2?
    example:
    __task void task1 (void){
      /* Obtain own system task identification number */
      id1 = os_tsk_self();
      os_tsk_prio_self(1);
      /* Create task2 and obtain its task identification number */
      id2 = os_tsk_create (task2, 2);
      for (;;) {
        /* Signal to task2 that task1 has compelted */
        os_evt_set(0x0004, id2); setting the flag here
        /* Wait for completion of task2 activity. */
        /*  0xFFFF makes it wait without timeout. */
        os_evt_wait_or(0x0003, 0xFFFF);
    __task void task2 (void) {
      for (;;) {
        /* Wait for completion of task1 activity. */
        /*  0x0004 represents bit 2. */
        os_evt_wait_or(0x0004, 0xFFFF);   should i wait here for same flag?
        /* Signal to task1 that task1 has compelted */
        os_evt_set(0x0003, id1);
  • "if i set the flag 1 in task1 , it means that i should wait for that perticular flag(flag 1) in task2?"
    That obviously depends on if your goal is that task 1 should activate task 2.
    If task 2 have (at least) same priority unless you put task 1 to sleep after having set the event. As usual, the OS will sort all runnable (not waiting for a delay to end or waiting for event, mail,...) on priority and only look at the threads that have the highest priority among the threads that are running. Threads with lower priority gets ignored. Threads still waiting for something that haven't happened (no timeout , no event, no mail, ...) gets ignored.
  • Thank you so much per.....
    now i resided to change my project procedure
    i want ADC to read the value for some time and display it on the LCD as well as Hyper terminal(using SCI protocol), buzzer should be turned ON and OFF according to events(as you mentioned earlier)
    is it possible??
    and what about the SPI() function where shall i put? and for what reason?
    OR should i develop it in different way?
    if so please suggest me..
  • Excuse me, but I believe most of us here are working right now. Can't you find a consultant (=pay) to do your homework for you?
  • in the below program its switching from tsk1 to tsk2 and tsk2 to tsk3
    but its again not going back to the tsk1 where tsk2 is going in to wait state....
    can anyone tell me why tsk3 is not going to the wait state?
      id3 = os_tsk_create (task3, 3);
      for (;;) {
        buzzer();/* ... place code for task1 activity here ... */
            os_evt_set(0x0002,id2);
      for (;;) {
        ADC();/* ... place code for task2 activity here ... */
            //os_evt_set(0x0003, id3);
            os_evt_wait_or(0x0002, 0xFFFF);
        //os_dly_wait(10);
    __task void task3(void)
            for(;;)
                    SPI();
                os_evt_set(0x0001, id1);
                    os_evt_wait_or(0x0003,0xffff);
                    os_dly_wait(15);
    int main (void) {
      /* Start the RTX kernel, and then create and execute task1. */
      os_sys_init(task1);
  • We don't even know if buzzer(), ADC() or SPI() takes long time in relation to os_dly_wait(15).
    You have done some debugging, haven't you? What happens when you singlestep the three threads?
    By the way - task 3 is waiting for os_evt_wait_or(0x0003,0xffff). But who is sending any event 0x0001 or 0x0002 to this thread? How long do you think the wait will be if the thread don't get anyone to set one or both of the events?
    Another thing - is there are reason why task 3 listens to two flags?
  • It looks a little as if the OP is copy-pasting pieces of code he finds in example programs without really understanding their impact (and then stumping with his foot: "it is not working!").
  • sorry sir i was commented it while posting.......
    after dumping the program its working i.e, it its going to task 1(buzzer is functioning )
    and one more doubt i have sir .... i am not able to find it in manual i.e,
    is it possible to run only one task for specific time out of 4 task??
