KeilC51 can not compile this code correctly
hi: I have a code below:
     char pop_value = 0X80;
     if(pop_value == 0X80)
         pop_value = pop_value;//point 1
     pop_value = pop_value;//point 2
I would have thought the code would jump to point 1 after logical judge, but the simulating result exceed my expectations that the code jumped to point 2. I watch the Disassembly code :
    82:             pop_value = 0X80;
C:0x0A68    7853     MOV      R0,#pop_value(0x53)
C:0x0A6A    7680     MOV      @R0,#P0(0x80)
     83:             if(pop_value == 0X80)
C:0x0A6C    E6       MOV      A,@R0
C:0x0A6D    FF       MOV      R7,A
C:0x0A6E    FD       MOV      R5,A
C:0x0A6F    33       RLC      A
C:0x0A70    95E0     SUBB     A,ACC(0xE0)
C:0x0A72    FC       MOV      R4,A
C:0x0A73    ED       MOV      A,R5
C:0x0A74    6480     XRL      A,#P0(0x80)
C:0x0A76    4C       ORL      A,R4
C:0x0A77    7002     JNZ      C:0A7B
    84:             {
    85:             pop_value = pop_value;
    86:
C:0x0A79    A607     MOV      @R0,0x07
    87:             }
C:0x0A7B    22       RET
                 PUTCHAR:
I can not find the error happened.so I also compile this C code in another project. the code can jump to point 1 after logical judge ,nor jump to point 2.I watch the the Disassembly code at once:
    61:      item = 0X80;
C:0x0A94    752400   MOV      0x24,#malloc_mempool(0x00)
C:0x0A97    752580   MOV      0x25,#P0(0x80)
    62:      if( item== 0x80)
C:0x0A9A    E525     MOV      A,0x25
C:0x0A9C    6480     XRL      A,#P0(0x80)
C:0x0A9E    4524     ORL      A,0x24
C:0x0AA0    7006     JNZ      C:0AA8
    63:      {
    64:      item =item;
C:0x0AA2    852424   MOV      0x24,0x24
C:0x0AA5    852525   MOV      0x25,0x25
    65:      }
my keiC51 version is V8.16. I don't know why the same C code has different assemble code in different project. The important thing is that the compiler make a wrong logical judge.
  • Read this and thought it must be 1st April.
    Surely this is a [really rather poor] wind-up.
  • I have found the reason
    No, you haven't. You haven't found anything. What you have done so far is imagine things.
    or the compiler would produce wrong disassemble code.
    So you've been claiming all through this thread. And all that while this judgement of yours has been based on incorrect assumptions about what qualifies compiler output as correct.
    I.e. you haven't found anything, and you haven't learned anything either. Which begs the question why you're even bothering to ask questions, given that you couldn't care less about the answers.
