I just updated to MDK-ARM 4.12, and in the process I got uVision 4.10. However, I don't like the new color coded tabs for open files, but I can't find a way to remove the colors. Is that at all possible?
And I am also not very happy with how uVision handles the file tabs either. The order of the open files should be retained between project close and reopen, but this does not work reliably. It didn't work fully in previous versions either, but it seems to have gotten worse.
Hi, I don't like the way the colours work, it would be great if the same .c and .h files were the same colour, but they aren't. You should also be able to switch this off! Thanks, John
I agree - the coloured tabs are dreadful. You can't tell which file you are viewing very easily, it seemed much more obvious when they were all grey.
Highlighting the open tab in a unique colour would be useful.
Another suggestion: Why not make it up to the users (us!) to decide the position and the color of each file tab?
We already have the possibility to change options for individual files, so it isn't that big a change.
Kind regards, Claus
