Code run on target via ULINK will not breakpoint
My apologies if this is a regular question, but this is driving me to bad pieces.
What we have here is
ToolChain pk51 Prof Developers kit Version 8.12
ToolChain Path C:\Keil\C51\Bin\
C Compiler C51.EXE v8.12
Assembler A51.exe v8.01
Linker/Locator LX51.exe v4.25
Librarian LibX51.exe v4.24
I am not sure how much else you may need.
I have an application which lives on an 8051 derivative controller. I can compile it ok, and the initial testing in the simulation was ok. So we ( more than one folks out here ) put it on the controller.
We use a Ulink 2.0 kinda -- its marked ULINK 2.1
Okay --- Once compiled for target and loaded on, we set some breakpoints in the text pane, flipped into debug and......
Sometimes the application starts immediately as if the run button got clicked. Other times one can push the reset button and then hit the go button. In either case, the process does not heed halt messages and will not stop at any breakpoints that were set earlier. You do not see the red square you put near a line -- you see a grey ghost.
We tried other PCs to run this procedure. Only one machine does not have the "set breakpoint" menu greyed out. Its the only one that can do debug on target. Our other three have set breakpoint greyed out while running on target, and its possible to start a run, but breakpoints are ignored.
The C51 project options window for the working machine as well as the problem children were compared and differing options were modified. This did not result in any improvement. We also tried different machines in case it was hardware. The good box runs ok, the rest do not. since we are all running the same machine ( a dell with windows xp ) I think it may be a sw option we did not see or set.
Any and all assistance in this matter is greatly appreciated. Flames cheerfully ignored. Accolades acknowledged. Even Better - What works will be posted back to share with the long suffering people!
  • First Up:
    My apologies as I have not reached a complete solution yet.
    This is what I did get:
    In examining folks machines and licenses, I kept seeing a reference to a v8 item in the license file, as well as a dll I did not have. Simply adding the dll had no effect.
    While doing a full tilt re-install, my sorrow showed in that my c51/bin directory was the same as before. Looking further seemed worthless, however I still looked around. I still had 8.12 software
    The local Mentor for this subsystem discovered he had a second cd. It has the same date ( 8/2008) as the first CD. Still, a try seemed minor so it was engaged on.
    It had 8.16a SW on it. This one placed the missing DLL in the bin directory as well as applying the v8 in my Tools.ini file. Some md5s in the bin directory did not match what I had seen in my before directory. The bins were different
    Hope for a success bloomed..... We retired to the Hardware lab to test out this development...
    I get the menu allowing breakpoints while in run. It is not greyed out. However, the machine did not acknowledge a stop command. The message displayed on the output window was ulink timeout. We had to disconnect the machine from power supply and turn off keil to get the PC back.
    What i am doing at this point is reviewing the link posted earlier to find out a few things on time outs. One point that is here that is real unique- We have the only 5 volt keil ulinks ever made.
    Will try to keep you folks posted as things resolve. Anything you can tell me on timeouts would be appreciated.
    --dan
