I was hoping to hear your opinion about a serious problem I have - it is either I solve it or reduce my LPC2478 CPU speed from 72[MHz] to 64[MHz] (11% loss. The problem does not seem to be occurring at lower MHz settings). I posted about this in the past but it was a long time ago. When I place a controller in an environmental chamber and increase the temperature to 80+ Celsius degrees, I often see data abort exceptions, and sometimes I get the impression that the PC takes a hike (even the firmware LED that blinks every 1 second becomes irregular for a while before it stops). The program is launched by a boot loader and has a lower level supporting firmware layer that handles some interrupts (not all). I also see that if RTX is not started at all (but the application hangs in a "for (;;)" loop instead, hence the bootloader and firmware layer were/are involved, but the application is idle) - the system never crashes! I have excluded, as far as I could tell, the roll of external memory or RTX in this situation. However, I still suspect RTX a little (even though my test programs never crashed). My question: did you ever encounter such a situation? Where do I look best? can this be the result of a misbehaving peripheral? NXP have confirmed the LPC2478 is not the reason.
Whatever happened to the days where people involved in firmware knew something about the fundamentals of the hardware on which their code would run?
Whatever happended to the days when people on the net always tried to help and be productive, instead of focusing 100% of all comments on harassing people?
Stunned character, I never used this word on this forum (I apologize to the rest of you in advance) as far as I can recall, but you really are an idiot. Really.
<sigh/>
Interesting argument. FYI, the erroneous clock signal was a direct product of higher temperature. One can induce this using even something as simple as a warm air blower directed at the DRAM, but this behavior is not documented anywhere nor does it happen with other DRAMs. So you see, this is what happens when one focuses on making empty arguments for the sake of making them rather than on the facts. This is engineering man, not religion.
"the erroneous clock signal was a direct product of higher temperature."
You stun me with every detail you provide.
"This is engineering man..."
LOL
Next time you go the liqueur store, Steve, try to be polite and remove the hard glued sticker from your forehead: "Born to be a loser".
