the origin 8051 is 12 clock cycles a machine cycles.
but my mcu is slilab.
most instructions execute in the same number of clock cycles as there are program bytes in the instruction
the design of the simulator conseider this ?
i think not.
"A simulator can never show you the jitter occurring from other events or different states of variables."
Yes, it can; but the Keil simulator will show you in terms of cycles - it will not actually run in real time.
what about interrupts?
Can be simulated.
Some from simulated timers etc.
Some from simulated external hardware.
Some from mapping the serial ports to debugger or real live serial ports.
Thank for all
As my poor English ,I can not make it clear.
But in my project, simulator is the same with chip, maybe as my chip's machine cycle is same with pulse cycle (instead of the traditional 12-pulse one machine cycle)
Problems end, once again thank all
