can open a large array as 1024bytes for CY7C68013 ?
since my topic use CY7C68013+AD7934+EEPROM as directly convert an analog signal to digital and send back to PC, but for the sampling rate of 10kHz, i want to have a buffer for me to save those data...and i have tried a lot of ways for opening a large array in KeilC...
but most of the time it's not access...
can someone else tell me how to create it...
and i would wonder ask... can i allocate it @ fx2reg.h? and how to finish it up?
one of my unsuccess way...
CODE:
#pragma NOIV
#include "fx2.h"
#include "fx2regs.h"
#include "fx2sdly.h"            // SYNCDELAY macro
extern BOOL GotSUD;             // Received setup data flag
extern BOOL Sleep;
extern BOOL Rwuen;
extern BOOL Selfpwr;
BYTE Configuration;             // Current configuration
BYTE AlternateSetting;          // Alternate settings
#define VR_NAKALL_ON    0xD0
#define VR_NAKALL_OFF   0xD1
#define WB     IOD_0
#define CS     IOD_1
#define RD     IOD_2
#define WR     IOD_3
#define CONVST IOD_4
#define BUSY   IOD_5
#define ALLOCATE_EXTERN
#define START_MEM01             0x1e00
#define LENGTH_MEM01    0x200
BYTE xdata *AD0DATA[]= START_MEM01;
void ad0(void);
void TD_Init(void)             // Called once at startup
void ad0(void)
        AD0DATA[count] = IOA;
        AD0DATA[count+1]= (IOB & 0x0f);
void T0int(void)                        //----timer 0 int----//
    CS=1;
    WR=1;
CONVST=1;
    OEA=0xff;
    OEB=0xff;
    TL0=0x0c;
    TH0=0xfe;
    if (count < 1023)
       count+=2;
    else
        count=0;
        TR0=0;
     ad0();
void TD_Poll(void)
        unsigned int i=0,j=0,loop=0;
    if(!(EP01STAT & 0x02))          //PC TO USB
     if(EP1OUTBUF[0]==0x05)  // Continous sampling and Sent to PC //
        freq=(EP1OUTBUF[2]<<8)+EP1OUTBUF[1];
        cycle=(EP1OUTBUF[4]<<8)+EP1OUTBUF[3];
            SYNCDELAY;
        EP1OUTBC=0x05;          // 5bytes data already be read
        SYNCDELAY;
        flag=1;
        count=0;
            TMOD=0x01;
           TL0=0x0c;
           TH0=0xfe;
        TR0=1;                  ET0=1;
        SYNCDELAY;
        times=0;
        while( times < cycle )
           if(!(EP2468STAT & bmEP6FULL))                       {
           j=0;
             for(i=0;i<64;i++)
              {                                         EP6FIFOBUF[j]=AD0DATA[j];
                EP6FIFOBUF[j+1]=AD0DATA[j+1];
             j+=2;
        EP6BCH = 0x00;
         SYNCDELAY;
                EP6BCL = 0x80; // arm EP6IN
         SYNCDELAY;
