Hi All, I'm trying to write to the Serial Window #1 at regular interval of time (But not successful yet). To generate the time interval i'm using timer0 of 8051 in 16 Bit Timer Mode 0x01 The values are initialized as shown below TH0 = 0xFF TL0 = 0x00 In the given program below, if I comment all the printf statements It works fine, generates accurate delay as needed (as seen in Debug Session). i.e. TL0 starts incrementing for every clock tick and when it reaches 0xFF, the next clock tick sets the overflow flag which in turn calls the ISR (Interrupt_Service_Routine0), wherein I again set the timer's TH0 and TL0 value. But if I uncomment the printf statements in the program (Func1 and Func2), I don't get accurate time delay (as seen in Debug Session). when control reaches Func1 and passes ahead of printf statement the TH0 and TL0 value changes to 0x06 and 0x52 respectively. As I have understood the timer 0 values should be between FF00 to FFFF (as initialized in the Timer_0_Init and Interrupt_Service_Routine0) Please do correct me if my understanding is not correct
Using Keil IDE uVision2 V2.38a Have selected ,b>Generic->8052 (all variants),/b> in the Options for Target in Project Menu The program is as shown below:
/*------------------------------------------------------------------------------ HELLO.C Copyright 1995-1999 Keil Software, Inc. ------------------------------------------------------------------------------*/ #include <REG52.H> /* special function register declarations */ /* for the intended 8051 derivative */ #include <stdio.h> /* prototype declarations for I/O functions */ #ifdef MONITOR51 /* Debugging with Monitor-51 needs */ char code reserve [3] _at_ 0x23; /* space for serial interrupt if */ #endif /* Stop Exection with Serial Intr. */ /* is enabled */ #define FUNC1 3 #define FUNC2 2 sbit Port1Pin0 = P1^0; sbit Port1Pin1 = P1^1; sbit Port1Pin2 = P1^2; sbit Port1Pin3 = P1^3; unsigned short myFlag = 0; unsigned short count = 0; /* --------------------------------------------------------- */ //Functions (Func1 and Func2)to be called from ISR void Func1() { // printf("Func1\n"); Port1Pin0 = 1; Port1Pin1 = 0; Port1Pin2 = 1; Port1Pin3 = 0; } void Func2() { // printf("Func2\n"); Port1Pin0 = 1; Port1Pin1 = 0; Port1Pin2 = 0; Port1Pin3 = 0; } /* --------------------------------------------------------- */ //Initializing TImer0 void Timer_0_Init(void) { TMOD |= 0x01; TL0 = 0x00; TH0 = 0xFF; ET0 = 1; TR0 = 1; EA = 1; } /*----------------------------------------------------------*/ //ISR for Timer 0 void Interrupt_Service_Routine0(void) interrupt 1 { TR0 = 0; //Deactivate Timer 0 TL0 = 0x00; //Setting timer Initial value again TH0 = 0xFF; //Setting timer Initial value again TF0 = 0; //Set Timer Overflow Flag to 0 TR0 = 1; //Activate Timer 0 ++count; if (myFlag == 0 && count > FUNC1) { //Call Func1 Func1(); myFlag = 1; count = 0; } else if (myFlag == 1 && count > FUNC2) { //Call Func2 Func2(); myFlag = 0; count = 0; } } /*------------------------------------------------------------*/ void main(void) { /*------------------------------------------------ Setup the serial port for 1200 baud at 16MHz. ------------------------------------------------*/ #ifndef MONITOR51 SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 221; /* TH1: reload value for 1200 baud @ 16MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ #endif Timer_0_Init(); while(1) { //Do Nothing, wait for Timer overflow which inturn calls ISR ; } }
Thanks for your Time and Help
But later on, when it matters, lives may be at stake, therefore I truly believe it can do no harm to pointing out glaring mistakes.
This is a bit like suggesting that every mechanical engineer should be an explosives expert in case he is every asked to design artillery.
In any case all I did was point out a glaring mistake and offer a correction. I didn't suggest that it was either a generally advisable or, in this case, useful course of action.
a total newby that does not bother to read documentation (i.e. student...)
I didn't think the OP fell into that category. His post seemed quite reasonable with a willingness to learn - not really deserving of a one line scoffing dismissal that wasn't even factually correct.
The sardine is very busy to 'teach' newbies routes that will get them in trouble.
Not at all. I just like to correct false information from the oldbies.
.... had I coded something and asked someone (no web) "what is wrong" and been told "You can successfully do this" I would have persisted up the road I was travelling and lost a lot of time.
When you make statements that are FALSE in 99.9% of the cases DO NOT DO SO WITHOUT stating all ramifications of doing so or you will lead many down the garden path.
How can you (in sardinespeak) state "You can successfully printf() from an ISR" without knowing if the OPs UART is interrupt driven or not?
How can you (in sardinespeak) state "You can successfully printf() from an ISR" without knowing the OPs program timnings?
How can you (in sardinespeak) state "You can successfully printf() from an ISR" without knowing the OPs printf frequency?
YES an advanced user may be able to pull some rabbits out of the hat, but to avoid misunderstandings either state the 99% truism or give ALL EACH and EVERY ramification of doing it
Thank You All (Erik, Hamed, Tamir, Jack) for your replies Sorry for putting you all in a heated argument. Erik Thanks for the clarification regarding using printf from main
a total newby that does not bother to read documentation (i.e. student...)...." can anyone of U please let me know where exactly can I get these documentations for reference Hence may be I will understand the root causes of the issue (being discussed in the current post) in a better way. Also understand the pros and cons of using printf (as discussed by Jack and Tamir) At present I'm referring the book "Embedded C by Michael J Pont" Also do suggest me some books if possible Thanks Again for all your Time and Patience
you can start by reading the 8051 bible, here:
www.semiconductors.philips.com/.../80C51_FAM_ARCH_1.pdf www.semiconductors.philips.com/.../80C51_FAM_PROG_GUIDE_1.pdf www.semiconductors.philips.com/.../80C51_FAM_HARDWARE_1.pdf
if you are interested in making your work better, try this link:
iapetus.neab.net/.../hardening.html
also, always work with static code analyzers. you can learn a lot from their findings (for example: PC-lint).
there are many other sources on and off-line. learning it is a never ending story.
Thanks All For Providing Your Valuable Inputs Thanks Tamir For The Links And Suggestions
I'm afraid that's your inability to read and understand things in context coming to the fore.
I pointed out that there were considerations. As one of the regular proponents of making people think rather than presenting them with a complete package I thought you'd approve.
That information is all readily available in the code the OP posted. However, these details are irrelevant - none of those things prevent one from being able to successfully printf() from an ISR.
I wouldn't have described calling printf() from an ISR as "pulling rabbits out of the hat", more a question of understanding the implications and consequences of doing so. Given that you view this as a magic trick only achieveble by an advanced user it would be a useful educational exercise for you to research and list the ramifications yourself.
Can somebody please quickly elaborate on the ramifications of calling printf from an ISR mentioned in this thread?
..... these details are irrelevant - none of those things prevent one from being able to successfully printf() from an ISR.
since when ?
One example of a relevant detail is that if putchar is ISR driven you can't. DO NOTE the MCU: above.
In most cases printf() from an ISR will lead to some other ISR not being serviced in a timely fashion or the ISR with the printf being constantly seviced i.e. it takes so long to execute that it is activated again before it is done.
Putting a printf in an ISR is an abhorrent violation if the KISS principle (keep ISRs short & simple)
One point to the above is that the problems can show up in an intermittent way making the debugging (of what is wrong in the first place) virtually impossible.
I'm afraid that's your inability to read and understand things in context coming to the fore. so, you are back to your old tricks, when you can not see a technical reason you go personal.
printf is not reentrant of a C51 (as far as I know).
The first 'C' compiler for the 8051.
Well, it is possible that the variant is specified somewhere in this thread and I've missed it, but I'm assuming that it's a pretty straightforward 8051.
I'm interested in your idea of an "ISR driven" putchar(). Here's a fairly generic putchar() implementation for interrupt driven serial communications:
/*------------------------------------------------------------------------------ ------------------------------------------------------------------------------*/ #pragma disable char com_putchar ( unsigned char c) { /*------------------------------------------------ If the buffer is full, return an error value. ------------------------------------------------*/ if (com_tbuflen () >= TBUF_SIZE) return (-1); /*------------------------------------------------ Add the data to the transmit buffer. If the transmit interrupt is disabled, then enable it. ------------------------------------------------*/ tbuf [t_in & (TBUF_SIZE - 1)] = c; t_in++; if (ti_restart) { ti_restart = 0; TI = 1; /* generate transmit interrupt */ } return (0); }
Could you give me some idea of how putchar() might be "ISR driven" and how that would prevent one from successfully calling printf() from an ISR?
Ok, there's ramification number 1 for your list.
Last time I heard KISS it meant 'Keep It Simple Stupid' which seemed rather more snappy.
This is why one needs to be aware of the ramifications.
You quote what I say removing the context, then comment on your interpretation of what is left. Either this is wilfull misquoting or it it a deliberate attempt to distract attention from your technical shortcomings.
I was giving you the benefit of the doubt, but there you go.
Could you give me some idea of how putchar() might be "ISR driven" and how that would prevent one from successfully calling printf() from an ISR? ... then each and every point you have made is moot
it is pointing out that because of YOUR "technical shortcomings" (re the '51 and C51)you resort to personal attacks.
