Execution speed
Hello friends
I have encountered a very strange problem, I have keil with MDK3.08a version. When i compiled program and loaded in the target the execution speed of the program becomes considerably slower (not in debug mode). I have compared the speed with the previous version of keil (i don't remember may be 3.20).
Furthermore when i interchange the location of C file in the work space it effects the execution speed. When I compared the output hex file of the same project with interchanged c files position in work space, i found they were different.
Please help me out of this
  • But Andy whole program depends upon execution speed, for example I2C driver in which you have to generate clock of the order of microseconds, then how could you say that do not rely on that. moreover if there is a difference in execution speed it will not be in the order of 10x
  • "...whole program depends upon execution speed, for example I2C driver in which you have to generate clock of the order of microseconds..."
    if you're requiring timing with that order of accuracy, you should seriously consider writing it in assembler.
  • " for example I2C driver in which you have to generate clock of the order of microseconds"
    You should certainly not be using 'C' loops to time an I2C interface - for precisely the reasons stated!!
  • Andy do you mean to say that only loops are affected. and if yes please tell me what about other loops which are not assosiated with delay
  • Absolutely no!
    Did you actually read what I wrote earlier:
    "you do not have control of the generated machine code "
    That applies to any & all HLL source code!
    (unless you are using some specific compiler extension that gives you some specific guarantee)
  • Split this into multiple problems.
    1) Figure out why you get a speed difference of 10x by moving a function from one memory address to another.
    2) Make sure that hw communication is using hardware acceleration where possible. With I2C in hardware, the code will not need to busy-loop. You will instead have an interrupt handler - or maybe a status bit to poll for completion.
    3) When doing things not suitable for hardware peripherials, then you should split it into short and long delays.
    - long delays are best handled using the timers. Either waiting for an interrupt, or busy-looping while polling an interrupt flag or comparing the current timer value with the expected timeout value.
    - short delays can be handled by sequences of NOP instructions. But you can't have a design where you rely on the majority of the delay to come from the compiler output of C code. You could possibly have a loop where the NOP instructions gives - at least - the required delay, and that any C overhead gives an unknown extra delay. But you would still have to make sure that the compiler sees some form of side effect that stops it from throwing away the loop in the first place. Good compilers normally treats their NOP intrinsic as a magic operation with side effects. The question you have to ask is if you want to rely on the compiler doing that - and that the compiler will continue to do that even if you are upgrading to a newer version - or maybe if you moves the code to a different compiler.
