Experts, I have a 'C' program that contains an array of around 10 unsigned int's. If I initialise it during the declaration, the code never enters main() (I placed a breakpoint on the first instruction inside my main() but it never got hit). unsigned int array[10]={0,0,0,0,0,0,0,0,0,0}; // does not work.
If I remove the initialisation part, it works. Why? MCU = C8051F340 (Silabs) Keil version = C51 COMPILER V7.10 Assembler command line flags: XR GEN DB EP NOMOD51 Compiler command line flags: PW(80) SB LC OT(9,Size) CD DB OE DF(__F340_VER__) Large Linker command line flags: RS(256) PL(68) PW(78) IX
Thanks.
Regards, Ganesh
Here: http://www.keil.com/support/man/docs/c51/c51_ap_init.htm
Handling of a Watchdog is specifically mentioned...
(in almost the way that Per suggested)
