Query about p0.14 / Bootloader in LPC2148
The manual says that if p0.14 is low while reset is low, forces on-chip boot-loader to take over control of the part after reset. However, when I connect this pin to ground, while the user code is executing (Blinky), the program stops! When I connect it to the 3.3V pin on the motherboard, Blinky starts running again! And all this time reset is never low.
Is this supposed to happen? It doesn't seem so according to the flowchart in the manual.
  • The chip manufacturer is NXP - or is it on a board that's mis-labelled?
    "I found it lying around"
    That's never a good way for a beginner to start!
    It might have been left lying around because it was faulty;
    It might have been damaged whilst lying around;
    etc, etc,...
    For a beginner, I'd recommend that you start with a proper kit - then at least you should be fairly sure that you have working hardware.
    I'd also recommend that you choose a complete kit; ie board, tools, debug adaptor, tutorials, samples, etc all bundled. Then, again, you should be fairly sure that everything should work together, and you don't have to mess about trying to gather a compiler from here, and a debugger from there, and some patches from somewhere else to make it all work, and examples that refer to features you don't have...
    Personally, I found the Luminary Micro Stellaris kits very good (dunno if it's changed since TI bought them, though). They led the way with complete boards with integrated debug - many others now do the same.
    If this is for work, then be careful to evaluate suppliers and ensure that they can provide you with adequate support.
  • Thanks Per and Andy!
    The board is mislabeled @ Andy
    Andy yeah, I don't have a proper kit, I basically scavenged for compilers and debuggers and I am facing all the problems you have mentioned.
    Thanks for your suggestions, I will buy a complete kit.
  • Well, I found a brand new board (but from the same manufacturer) and tried a modified version of Blinky:
    1. I blink 4 LEDs in succession, with the frequency increasing after each iteration in 10 steps, and then it repeats. Basically, 1>. I know the program is running and 2>. there isn't any problem of repetitive reset or 3>. of external interrupt.
    2. My code does nothing to pin 0.14, so it is set to defaults, as a gpio, input direction.
    3. I thought that by applying 5V to the pin something is going wrong, but now, I apply 3.3V and get the same problem!
    I press the reset button and the program stops.
    Now, I apply 3.3V to p0.14 and the program starts again...without pressing the reset button!
    On top of that, when I stop applying 3.3V to the pin and then start again, the program stops!
    And I can do this forever.
    It seems to be a hardware problem, but can I be sure? It's a new board, but from the same manufacturer.
  • Sorry for providing a half-correct reply to the OP.
    It is always important that a beginner gets a good teacher like Per and Andy.
  • Just chatting.
    I had been forced to use the TI/Luminary Stellaris Serial-to-Ethernet Reference Design Kit, because "they know" that, it is a ready-to-use kit. Though I tried to explain to them that, I don't have any experience on Cortex-M3 and Luminary devices, and it doesn't look like a complete Evaluation Kit. The decision had been made, and I had to use this Luminary S2E RDK. While I have been working on the original RS485 Data Collector project, and the USB based I/O board project, at the same time, I could not spend too much time on the Luminary S2E RDK. Especially, "they know" that, it is a ready-to-use kit, it would not take me too much time.
    So, with my limited experiences on NXP LPC2000, I erased the LMI bootloader very successfully, and failed to make this kit/MCU work again. Finally, It took me two weeks to make sure what happened and recover the kit/MCU to the original state.
    1. The LMI S2E RDK is not a complete Evaluation Kit.
    2. The LMI bootloader is erasable, but NXP bootloader is not.
    3. The LMI bootloader of my S2E RDK does not support UART update, but most (?) NXP bootloader does.
    4. The LMI EK board has ICDI, but the LMI RDK doesn't.
    5. The LMI bootloader project (Source Code) of my S2E RDK does not configure well for my LMI MCU.
  • After one week debugging, I found a hardware problem on my TI/Luminary Stellaris Serial-to-Ethernet Reference Design Kit. The DB9 connector on my board is a wrong one. It should be a female connector, but what I got is a male one. So the pin connection is incorrect, and the RS232 behavior is strange.
    I am a software engineer, and this is a Ready-to-Run kit.
  • Are you sure that the board is incorrect? Is the signals wired as DTE or DCE?
    Serial ports exists in both variants, depending on if the unit is a DCE (Data Communications Equipment) or a DTE (Data Terminal Equipment). Basically if it is a "modem" or a "computer".
    So the board will only be incorrectly designed if it has the data signals incorrectly switched - RXD where TXD should be or RTS where CTS should be - in relation to it being a male or female connector.
    Note that when connecting a DCE with a DTE you have RXD to RXD and TXD to TXD. On the DCE (modem) RXD is an output for the data received from the phone line/optical fibre, while on the DTE (computer) RXD is the input.
    Follow this link and scroll down until you see two diagrams for null-modem and straight cables:
    printcapture.com/faq.html
  • Hi Per,
    Many thanks for your help.
    At that moment, I just wanted to complain, so I did not provide enough information.
    The TI/Luminary Serial-to-Ethernet Reference Design Kit consists of a S2E Module, a S2E connector board (MS2E-CKIT), and some cables.
    The MS2E-CKIT board which I got, is mounted with a DB9 male connector. The DB9 serial cable which I got, is one end male and one end female. And on the PC side, the COM Port adapter is male.
    S2E-RDK:male <-> male-cable-female <-> X86-PC:male
    So, I used a female to female converter to connect all this stuff.
    S2E-RDK:male <-> female-converter-female <-> male-cable-female <-> X86-PC:male
    I did not perform any real testing, I just simply run the example project from Luminary, and it "seemed" work. (My mistake)
    After suspending this project for quite a long time, recently, I wanted to do some Hello-World thing on this S2E RDK. But I didn't have enough time to read all the Luminary documentations. I did some Try and Error thing, modified the example project from Luminary, and of course, it did not work.
    I can send data from PC to MCU, but can not send data from MCU to PC.
    Because I did not read the Luminary documentations, so originally, I thought that, there was something wrong with my modification.
    After one week debugging (also doing something else), I started to suspect that what I were facing was a hardware problem. So I tried to obtain the MS2E-CKIT schematics, and found NOTHING in the CD of the S2E RDK. But fortunately, Google brought me to the below URL.
    e2e.ti.com/.../226147.aspx
    The MS2E-CKIT schematics:
    e2e.ti.com/.../S2E_5F00_CKIT_5F00_RB.pdf
    With the MS2E-CKIT schematics, and some other photos, I noticed the DB9 connector on my MS2E-CKIT board should be a female one. So I made my own female to female converter with my terrible soldering skill. After changing the wiring again and again, it worked, I can send data from MCU to PC successfully.
    With the solid evidences, (It is a ready-to-run kit from TI/Luminary, we expect the quality should be good at least.) I reported to my supervisor, he is good at 8051 hardware designing and 8051 assembly programming. My supervisor did more tests and replaced the DB9 male connector with a female one.
    So, we believe the DB9 connector on the MS2E-CKIT board is incorrect. It should be a female DB9 connector by design.
  • Hi Per,
    I am re-reading your post. So, you mean the DB9 male connector could be for another device which is not a PC?
  • the DB9 male connector could be for another device which is not a PC
    If this is the case, then it is a mismatch with the example project and the schematics.
    But yes, The most common application for the S2E module is for augmenting legacy products that contain a serial port for a configuration or control interface. Simply installing a S2E module into the legacy serial device provides instant networking capability with no major board redesign or software changes, a tiny form-factor for unobtrusive implementation, and cable lengths much longer than what is available for simple serial connections.
