Hi, I use AT89S52 in a project. I send and receive data through TXD, RXD pins to a GSM module for sending SMS to another mobile equipment. I use watchdog facility and the watchdog counter is reset at every 256 counts. My crystal frequency is 11.0592 MHz. It happens once in a while that the uC doesn't respond and remains as if it hangs. Then it has to be RESET again. I doubt whether it happens while serial data reception and sending happens simultaneously. I wrote the program in C using KEIL IDE. My questions are 1) What are the special precautions to be taken in this case?(sending and receiving simultaneously) 2)why this happens even when the watchdog is active? It will be highly appreciated if anybody can give some guidance.
No
Must be a different AT89S52 to the one I've used.
Assuming Jack Sprat is right (and I tend to believe he is) then your chip could be resetting and failing to start up properly - hence, your program does not get stuck at all during normal operation. It fails, "getting stuck" in the aftermath of a reset or in a failure handler (again, not being a C51 guy I cannot elaborate). Have you ever consider to actually debug this instead of shooting blanks? Ever considered adding a tiny trace buffer to track your program behavior etc.? Your situation is indeed hopeless, and it shall remain so unless you decide to do something to change it.
this could explain why the watchdog has no effect - maybe your program does not even get the chance to configure it during startup after the failure...?
Or it could be that the watchdog did have the desired effect of resetting the processor, but the processor then hangs somewhere before the app starts.
Maybe there's a power supply glitch - is there a proper supervisor circuit in the system?
I couldn't clearly understand what is meant by default situation after reset. I thought whether my program makes all the O/P pins high initially. For that I said no since I make some low during initialization.
This seems to be very valid. My equipment works in a noisy (electrical noise) environment. I also think that the noise pick ups in the power supply may be coming to the reset pin and causing error. With RESET high all the O/P pins go high. Is it possible that a spike on the reset pin can cause all pins go to high state and remain like that? If so, can you suggest some solution for that? What do you mean by proper supervisor circuit?
I couldn't clearly understand what is meant by default situation after reset RTFDS all SFRs have their 'reset state' defined there. If not change manufacturer.
Yes. All O/P pins high is the default situation.
The equipment has been continuously working for the last two months. But it hanged 4 OR 5 times when I had to power OFF and ON .
All O/P pins high at reset
this thread has been going on for a long time and it is time for "exotic guesses"
one such would be that you hang on a non-initialized variable that by sheer coincidence happens to be good when the processor powers up (memory at power on is random) and makes you hang when a WD reset happens (where the memory contents are preserved).
1)It never went to a hang situation while switching ON. 2)It never went to such situation when tested in my place (actual working condition is electrically noisy) 3) I initialized all variables. Do you think that spikes in suply line OR RESET pin can cause similar situation?
OP: I think he might be suggesting you are using an uninitialised variable somewhere in your code. But I'm not too sure.
the methods to handle noise sensitivity are described here www.8052.com/.../119926
CLEARLY you have TWO problems a) you are noise sensitive b) you either miss a supervisor or your WD is handled wrong.
Yes!
That is precisely why a large variety of Supervisor circuits is widely available from a number of manufacturers...
Many of these also include a hardware watchdog...
You're not using an RC reset generator, are you...?
