is it possible to call a c-function during the initalization of the startup-file? Could you give me one simple example?
; Reset Handler EXPORT Reset_Handler Reset_Handler ; open lowlevelinit c-function ; IMPORT LowLevelInit ; Setup Power Management Controller (PMC) -------------------------------------- IF :DEF:NO_PMC_INIT ELSE IF PMC_SETUP != 0 LDR R0, =PMC_BASE
Do you know any important things writing this init-function? How do the startup-file know the place / the c-file , where the function is declared?
best regards Alan
my lowlevelinit function is:
void LowLevelInit(void) { // turn on the main oscillator // AT91C_BASE_PMC->PMC_MOR = AT91C_CKGR_MOSCEN; while (!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MOSCS)); // enable PLLA for 198.656Mhz AT91C_BASE_PMC->PMC_PLLAR = 0x2060BF09; // Enable the clocks to all the on-chip peripherals AT91C_BASE_PMC->PMC_PCER = 0xed2fff9f; // set Master Clock divide by 2. AT91C_BASE_PMC->PMC_MCKR = AT91C_PMC_MDIV_1; // first switch MCK to slow clock AT91C_BASE_PMC->PMC_MCKR = AT91C_PMC_CSS_PLLA_CLK | AT91C_PMC_MDIV_2; }
best regards Scott
Scott, You said that your processor is "not running properly". Again - what does that mean exactly?
If I use the original startup code, and try to debug, then the processor is starting in supervisor mode and I'm not able to see my c-code within the disassembly. After a short moment, the debugger will stop (the last address is 0xFFFF... whithin the registers)...
If I comment the main oscillator startup and the pll init then the programm is running and I can debug the code.
maybe your PLL settings are bad?
that's the whole setup code for both plls and the main oscillator.
I don't use the pll b (and I also tested the code without the pll b). Pll_a (divider is 13 and multipler is 141), the main oscillator is 18.432 MHz -> I get a nearly 200 MHz system clock. The master-clock (bus-block) is the half of the 200MHz clock.
So I think all settings must be ok.
; Setup Power Management Controller (PMC) -------------------------------------- IF :DEF:NO_PMC_INIT ELSE IF PMC_SETUP != 0 LDR R0, =PMC_BASE ; System Clock Enable LDR R1, =PMC_SCER_Val STR R1, [R0, #PMC_SCER_OFS] ; Peripheral Clock Enable LDR R1, =PMC_PCER_Val STR R1, [R0, #PMC_PCER_OFS] ; Setup Main Oscillator IF (CKGR_MOR_Val:AND:PMC_MOSCEN) != 0 LDR R1, =CKGR_MOR_Val STR R1, [R0, #CKGR_MOR_OFS] ; Wait until Main Oscillator is stabilized MOSCS_Loop LDR R2, [R0, #PMC_SR_OFS] ANDS R2, R2, #PMC_MOSCS BEQ MOSCS_Loop ENDIF ; Setup the PLL A IF (CKGR_PLLAR_Val:AND:PMC_MUL) != 0 LDR R1, =CKGR_PLLAR_Val STR R1, [R0, #CKGR_PLLAR_OFS] ; Wait until PLL A is stabilized PLLA_Loop LDR R2, [R0, #PMC_SR_OFS] ANDS R2, R2, #PMC_LOCKA BEQ PLLA_Loop ENDIF ; Setup the PLL B IF (CKGR_PLLBR_Val:AND:PMC_MUL) != 0 LDR R1, =CKGR_PLLBR_Val STR R1, [R0, #CKGR_PLLBR_OFS] ; Wait until PLL B is stabilized PLLB_Loop LDR R2, [R0, #PMC_SR_OFS] ANDS R2, R2, #PMC_LOCKB BEQ PLLB_Loop ENDIF ; Setup the Master Clock and the Processor Clock LDR R1, =PMC_MCKR_Val LDR R2, =(PMC_MCKR_Val:AND:0x0000031C) ; Program MDIV and PRES fields only STR R2, [R0, #PMC_MCKR_OFS] ; Wait until Main Master Clock is ready MCKR_Loop1 LDR R2, [R0, #PMC_SR_OFS] ANDS R2, R2, #PMC_MCKRDY BEQ MCKR_Loop1 ; Program MDIV and PRES with CSS STR R1, [R0, #PMC_MCKR_OFS] ; Wait until Main Master Clock is ready MCKR_Loop2 LDR R2, [R0, #PMC_SR_OFS] ANDS R2, R2, #PMC_MCKRDY BEQ MCKR_Loop2 ; Setup Programmable Clock Register 0 LDR R1, =PMC_PCK0_Val STR R1, [R0, #PMC_PCK0_OFS] ; Setup Programmable Clock Register 1 LDR R1, =PMC_PCK1_Val STR R1, [R0, #PMC_PCK1_OFS] ; Setup Programmable Clock Register 2 LDR R1, =PMC_PCK2_Val STR R1, [R0, #PMC_PCK2_OFS] ; Setup Programmable Clock Register 3 LDR R1, =PMC_PCK3_Val STR R1, [R0, #PMC_PCK3_OFS] ENDIF ENDIF ; of IF :DEF:NO_PMC_INIT
