Who can tell me how RTX-tiny manage the task stacks in more detail?
Due to my limited English ability, it is not easy to describe my guess about Yu Zhou's requirement in writing. So I did some "Copy & Paste & Modify" works to output that unreal "The Insider's Guide To KEIL RTX51 Tiny", it is only for clarifying Yu Zhou's requirement.
What I have found is an article talking about "Adding the Priority Feature to RTX51 Tiny with source code". With this finding, I know:
1. The source code of RTX51 Tiny is available. 2. Someone has done some research on it and has made a patch to add the Priority Feature to it.
So it is possible that someone also has written some detailed documentation and/or research report for RTX51 Tiny.
"What I have found is an article talking about 'Adding the Priority Feature to RTX51 Tiny with source code'"
So, how about posting a link to that article, or describing where you found it?
"The source code of RTX51 Tiny is available"
Yes, it says so herre: http://www.keil.com/rtx51tiny/specs.asp
Has anyone looked into the C51/RtxTiny2/Source files that comes with the PK51. It sure looks like source files in ASM to me. Bradford
Yes - just like it says on the tin: http://www.keil.com/rtx51tiny/specs.asp
Hi Andy,
I didn't post that link, because I am not sure, if posting that link is safe to me and the author of that RTX51 patch.
Let me check http://www.keil.com/rtx51tiny/specs.asp first.
PS. I come from a region using Traditional Chinese; and I assume Yu Zhou comes from a region using Simplified Chinese. So the mentioned article is written in Simplified Chinese.
1. Is it safe to re-distribute the source code of RTX51 TINY Version 2 with your patch? 2. You have to be a registered member to download the attachment, and they only provide the Simplified Chinese interface. 3. Hi Andy, may I have your email address? You do not work for KEIL, right?
http://www.keil.com/support/man/docs/tr51/tr51_stackmgmt.htm
Jon
The infomation provided by Jon Ward is not detail! I need to know how the rtx to manage mutilple task stacks?
1) Why
2) Get the source code.
The information is, presumably, what Keil think is sufficient to enable you to use the product to its intended purpose.
If you don't consider it sufficient, then you need to expain in detail what other information it is that you require!
As it's part of the PK51 kit you must, presumably, have a valid licence? In which case, you should contact Keil support.
Is this forum only able to discuss how to use keil's products? I just want to discuss some theoretical knowledge!!! I just want to know everybody how to implement the task stacks if you are an author of tiny rtx!!!
"I just want to discuss some theoretical knowledge!!!"
Theoretical? OK.
"I just want to know everybody how to implement the task stacks if you are an author of tiny rtx!!!"
Now not theoretical, but very specific. Make up your mind.
Yu Zhou,
Theoretical?
Do you read Chinese?
Small RTOS51
Book -> www.bookschina.com.tw/602060.htm
Source Code -> " href= "http://www.zlgmcu.com/philips/philips-embedsys.asp">www.zlgmcu.com/.../philips-embedsys.asp)
So you didn't bother to check that before posting, then?
"The Keil Discussion Forum is an open forum where you may post questions and comments about Keil products." http://www.keil.com/forum/ You should never post to any internet forum before you have confirmed that you are "on-topic"
So,thank guys,now i know what this forum for! Howerver,you know,i am newbie of embeded knowledge,so you guys can tell me where i can discuss the base knowledge!???
