Getting odd floating point results.
((lat2-lat1)*BETA*(lat2-lat1)*BETA + (long2-long1)*delta*(long2-long1)*delta)
I'm writing some C code and I am getting some screwy results. Basically lat1, lat2, long1, long2 are all latitudes and longitudes in radians, delta is another precalculated parameter. BETA is a defined constant.
As far as I can tell this code always results in an answer equal to BETA regardless of changing inputs. Additionally when I brake out the two addition terms: (lat2-lat1)*BETA*(lat2-lat1)*BETA and (long2-long1)*delta*(long2-long1)*delta), and compute them separately I get a result of "0". I have been trying to wrap my head around what is wrong without success for a day now. Any suggestions for things to try would be appreciated.
Thanks in advance.
  • But in your case, you will get very large numbers because you do not divide with 2*pi before you square.
    That's got nothing to do with the problem. Given his input coordinates are in radians, dividing by 2*pi would be correct only if accompanied by multiplying the result by (2*pi)^2 afterwards --- a waste of effort for nothing unless intermediate results were in danger of hitting overflow. Which they aren't.
    If one really wanted to reduce number scales, it's the earth's radius in meters that should be factored out:
    ecc=ALPHA/BETA # a constant
    arc_lat = lat1 - lat2
    arc_long = ecc*cos(lat1)*(long1-long2)
    result_angle = hypot(arc_lat, arc_long)
    result_meters = result_angle*BETA
  • Thanks all for the help, I believe I have resolved this with your help.
            arc_lat = lat1 - lat2;
            part1 = cos(lat1);
            part2 = long1-long2;
            arc_long = ECC*part1*part2;
            part1 = pow(arc_lat,2);
            part2 = pow(arc_long,2);
            return BETA * sqrt( part1+part2 );
    Without using pow() I could not get valid results for computing the hypotenuse...
  • This algorithm is used for short distances. For that reason these assumptions produce what I would call an acceptable error (1 to 2 meters of error for a 500m measurement). While more elegant solutions are possible, it does not mean they are necessary. If I ever did find a need to squeeze more accuracy out I could always use more locally defined radii for the specific area of interest.
    Thank you for your suggestions, regardless.
  • Without using pow() I could not get valid results for computing the hypotenuse...
    So are you telling us that not only did you observe a difference between pow(x,2) and x*x here, but pow(x,2) was closer to correct? Now that would be seriously worrying. If there's a difference at all, it's pow() that should be less precise than simple multiplication.
    What were the actual results for both methods?
  • What I mean by invalid results was the same supposed cancellation problem we were discussing before. x*x resulted in a 0 answer where pow(x,2) gave me an acceptable result.
