about the process of instruction fetch
Hi: I have read one of the app note that keil provided "in-system flash programming"
(http://www.keil.com/support/docs/2364.htm)
and became confused. In my opinion, the uC core can only fetch instruction from rom or flash. But as the app note said, the code can be execuated in ram(using srom class). The way of copy the code from flash to ram can be easily understand, but how can it execuate there. In my opinion, the process of how to fetch instruction is only decided by the core construction, but not the complier or linker tools. what is the real instruction fetch mechanism about 51MCU. Is there any document related ? I do not know search what key point for this question. Thaks for your help.
aaa1982
  • It means whatever the specific datasheet defines it to mean! One might hope that any given manufacturer would use a consistent definition across their product range - but there's no reason to assume that different manufacturers would necessarily choose the same definition!
  • You are reading:
    "CPU Active (Normal Mode, fetching instructions from Flash)"
    while I think you should read:
    The big current consumption is from the CPU core running instructions, not from the flash being powered.
    It is only when
    "PU Inactive (Idle Mode, not fetching instructions from Flash)"
    that the core is using so little power that you may gain a good extra power save by cutting the power to the flash. But that requires that the CPU does have such an option.
  • when I use an external ram (C8051f320 do not support but c8051f340 support).
    The SILabs chips do not support external CODE memory. it is not a matter of RAM/ROM/flash ... it is a matter of CODE memory.
