Problem with IAP on LPC2138
The IAP is driving me crazy. When I single step my code using ulink it works, but when I just let it run the micro reboots itself and the IAP hasn't worked. I've read the manual, AN10256, searched the forums and looked at the sample code.
Here's my code:
ErrorCode_t writeBufToOneFlashSector(uint8_t secNum)
    BOOL good = TRUE;
    ErrorCode_t retCode = ERR_NO_ERROR;
        unsigned int enables;
    BOOL pllStat;
    // Disable interrupts during erase and write operations
    // Keep a copy of what was enabled
    enables = VICIntEnable;
    command[0] = IAP_PrepareSectors;
    command[1] = (uint32_t)secNum;
    command[2] = (uint32_t)secNum;
    waitTXComplete();
    pauseTX(TRUE);
    pllStat = usePLL(FALSE);
    iap_entry(command, result);
    good = (BOOL)(IAP_CMD_SUCCESS == result[0]);
    if(!good)
        usePLL(pllStat);
        retCode = ERR_IAP_ERASE_PREPARE | ERR_NUM_USED;
        errVal = (ParamType)result[0];
    else
        command[0] = IAP_EraseSectors;
        command[3] = XTAL_OSC_KHZ;
        VICIntEnable = 0;
        VICIntEnable = enables;
        if(!good)
            usePLL(pllStat);
            retCode = ERR_IAP_ERASE | ERR_NUM_USED;
    // See about doing the write
    if(good)
        if(!good)
            usePLL(pllStat);
            retCode = ERR_IAP_WRITE_PREPARE | ERR_NUM_USED;
    // Ready to write at last
    if(good)
        command[0] = IAP_CopyRAMtoFlash;
        command[1] = SectorStartAddr[secNum];
        command[2] = (unsigned int)nvBuf;
        command[3] = FLASH_NV_PAGE_SIZE8;
        command[4] = XTAL_OSC_KHZ;
        VICIntEnable = 0;
        usePLL(pllStat);
        if(!good)
            retCode = ERR_IAP_WRITE | ERR_NUM_USED;
    pauseTX(FALSE);
    return retCode;
