I'm just implementing the Keil HID sample code, but I found some strange things even the compiler complains about:
In usbcore.c there are some variables used without being set before. The variables are "alt" in USB_SetConfiguration() and "msk", "old", "alt" and "ifn" in USB_SetInterface().
__inline BOOL USB_SetConfiguration(void) { USB_COMMON_DESCRIPTOR *pD; DWORD alt, n, m; : case USB_INTERFACE_DESCRIPTOR_TYPE: alt = ((USB_INTERFACE_DESCRIPTOR *) pD)->bAlternateSetting; break; case USB_ENDPOINT_DESCRIPTOR_TYPE: if (alt == 0) { : } : }
The code at USB_ENDPOINT_DESCRIPTOR_TYPE is executed when "alt" is 0 by chance only and setting "alt" in USB_INTERFACE_DESCRIPTOR_TYPE has no effect as "alt" is an auto-variable loosing it's contents after USB_SetConfiguration() is finished.
USB_SetInterface() shows similar things.
The source code does work in my environment, but I'm anxious that this is by chance only.
Could anybody explain me how to come to a more reliable solution?
BTW: Code parts like
(BYTE *) pD += pD->bLength;
in a sample code scare me even after more than 20 years C programming (Realview complains as well).
Regards Herbert
Tsuneo,
nice to see the guru dropping by ;-)
Regarding Keil's HID sample code I would like to know how difficult it is to make it functional for Linux as well. As far as I know not answering GET_REPORT(Feature) is one of the problems causing not to be operable under Linux but there may be others as well.
Do you have hints for one being not familiar with 1000+ pages of the USB spec ?
Robert Rostohar wrote: "BTW: These functions are tested and work as expected and also pass the USB compliance test."
Really? :-)
A minor bug found by USBCV
I've tested this example on USBCV (USB compliance test of USB-IF)
LPC2368 / LPC2378 USB HID (Human Interface Device) Example http://www.keil.com/download/docs/335.asp
USBCV1.3.2 www.usb.org/.../tools
USBCV reports this error for Ch.9 test - ConfigDescriptorTest_DeviceConfigured - ConfigDescriptorTest_DeviceAddressed ERROR Device Reports BUS Powered in configuration descriptor and is currently SELF powered. FAIL (1.2.36) A Device must report the same type of power in the configuration descriptor as in GetStatus.
HID test completes successfully.
Above bug is caused by this lines,
#define USB_CONFIG_BUS_POWERED 0x80 #define USB_CONFIG_SELF_POWERED 0xC0 usbcore.c __inline BOOL USB_SetConfiguration (void) { ... if (((USB_CONFIGURATION_DESCRIPTOR *)pD)->bmAttributes & USB_CONFIG_SELF_POWERED) { USB_DeviceStatus |= USB_GETSTATUS_SELF_POWERED; } else { USB_DeviceStatus &= ~USB_GETSTATUS_SELF_POWERED; }
The condition of "if" clause is TRUE, even when USB_CONFIG_BUS_POWERED is assigned to bmAttributes, because USB_CONFIG_SELF_POWERED doesn't work as a good mask for bit 6. Then, Get_Status( DEVICE ) always returns USB_GETSTATUS_SELF_POWERED, regardless of bmAttributes.
This bug is a minor one, it just affects Get_Status( DEVICE ).
Tsuneo
Hello Herbert,
"Regarding Keil's HID sample code I would like to know how difficult it is to make it functional for Linux as well."
USB is a standard protocol. As long as you follow the USB spec, your device works on any OS (, in principle :-) ). Surely, Windows give us some (many?) exceptions, but Linux doesn't have so much exception. I don't see any problem on the HID example which disturbs working on Linux.
"As far as I know not answering GET_REPORT(Feature) is one of the problems causing not to be operable under Linux but there may be others as well."
The example declares no feature report. Then, even if you see STALL for GET_REPORT(Feature), it is the expected result.
- Declare a feature report in the report descriptor - Modify HID_GetReport() handler
hiduser.c /* * HID Get Report Request Callback * Called automatically on HID Get Report Request * Parameters: None (global SetupPacket and EP0Buf) * Return Value: TRUE - Success, FALSE - Error */ BOOL HID_GetReport (void) { /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: GetInReport(); EP0Buf[0] = InReport; break; case HID_REPORT_OUTPUT: return (FALSE); /* Not Supported */ case HID_REPORT_FEATURE: /* EP0Buf[] = ...; */ /* break; */ return (FALSE); /* Not Supported */ } return (TRUE); }
