Hello to All
what is the different between printf & sprintf and scanf & sscanf
I read the help but i dont understand it
printf("Hello world \n"); aprintf("Hello world \n"); ------------------------------ int k; scanf("%d",k); sscanf("%d",k);
Thanks = 10x
Mayer
In words of one syllable YES You can use it for an innumerable number of things.
The important thing is to start with what you need (IE define a problem) then look at what you have (IE what C functions that may be used to meet said need).
I use printf to dumb data to a serial port print formated data to a graphic LCD (lots of fancy stuff processing said data underneath granted), and dump memory information (in my case contents of specific data structures). It can be used with pretty much ANYTHING that needs formated text, that is what it was designed and intended to be used for.
The limitation of what it can be used for however is what you need to do.
Stephen
