HI ALL
need help .any source code to Microcontroller sound record with eeprom memory chip. i know i need mic and spkr on the port pins.
Thank you in advanc
Yes, he might know more than you.
But right now, you know too little to be able to ask a coherent question that we can relate to.
An important question: What do your teacher expect you to do, and what part of your project does he expect this forum to do for you?
Your next step: Read through the instructions you have received a couple of times more. Are you expected to play with sound on "any" microcontroller, or do you have a specific board where you are expected to do your work?
Does that board come with Linux?
Does that Linux port contain support for sound, or are you supposted to write drivers for manipulation of sound and/or for reading/writing sound to the EEPROM?
If you are going to ask questions here, you must first make sure that the questions you ask are relevant, and that we have enough information to be able to know the intentions of your teacher.
HELLO,
you dont you know the gp2x????????????
why you did not say it??????????????
you lern from me???????????????????
it has linux and sound and tuch screen and arm and memory and eeprom and sdl libs for coders and comunity forums.
i can write code with pc and run code on pc and gp2x!!!!!!
Per, Coming man, this guy is helpless. Let him sink in the mud...
I meant: hopeless!
I meant, of course: "Come on man..." this guy and his gp2x console drive me nuts :) :) :)
HIPI !!!
problem solved.
now leave us alone please.
I quote your original post in full. Pleas tell me how many times you remembered to mention the term "gp2x" in your text:
"HI ALL
Thank you in advanc"
see http://www.gp2x.com
i have serial number 102164 and bob
but of course you do
This thread, like many others before it, is drifting rapidly into the direction of (voluntary or involunatry) satire.
which processor is in the thingy the OP has
arm920t and arm940t
yes it has to microporcesors and has video and bob.
it has emulaters and games on cards!!!!!!
see http://www.gp32x.com for my forums
I just KNEW he would answer that one...
then why did you start with MUC non-specific ?
see http://www.gp32x.com for my forums "my forums" so you are the manufacturer of the thingy and this is noting but a thinly veiled scam to try to get someone less well equipped in the higher elevations to buy your thingy.
"then why did you start with MUC non-specific ?"
To quote myself:
"I think we have to assume we have one more troller, and ignore this thread."
