I need to write a custom USB controller to communicate with a PC. Over the USB we will perform firmware upgrades, upload new operating parameters, download device performance data, etc. The PC side will use WinUSB mechanism to manage the USB device. I need to implement the USB control using a single interface with 2 bulf transfer endpoints, input and output. Have experimented with the USB CDC device example that came with the Keil toolset. I was thinking of taking that example and modify the descriptors and remove any unneeded logic that implemeted the CDC device and add what I need for my project.
Does this seem like a reasonebly place to start? For example, are the handling of the control endpoint esentially the same regardless of device class type?
I use LPC2378 in MCB2300 and I test usbmem demo and it works well. But when I change the bulk endpoint from EP2 to EP5, this demo works failed. In LPC2378, EP2 and EP5 are for bulk data transfer.
Does anybody know why. Thank you
There are three parts I modify for bulk EP5: (1) In usbdesc.c : /* Endpoint, EP5 Bulk Out */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(5), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(USB_CDC_BUFSIZE), /* wMaxPacketSize */ 0x00, /* bInterval: ignore for Bulk transfer */ /* Endpoint, EP5 Bulk In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(5), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(USB_CDC_BUFSIZE), /* wMaxPacketSize */ 0x00, /* bInterval: ignore for Bulk transfer */
(2) In cdcuser.h : #define CDC_DEP_IN 0x85 #define CDC_DEP_OUT 0x05
(3) In cdcuser.c : void USB_EndPoint5 (DWORD event) { switch (event) { case USB_EVT_OUT: CDC_BulkOut (); /* data received from Host */ break; case USB_EVT_IN: CDC_BulkIn (); /* data expected from Host */ break; } }
Stay in your own thread, and don't attack every thread you can find that has with USB to do... http://www.keil.com/forum/docs/thread13496.asp
Tsuneo,
I did get this all working, I am trying to now port this to a 2468 processor. I started with a similiar Keil mass storgae device example for 24xx, comparing all the files there were minimal differences, mostly the USB_Init and ISR routines. After making the changes and carefully double checking I can not get the host to recognize the device.
I'm running out of debugging ideas, is there anything you can suggest? I do see the IUSB_SR firing on reset, it executes a USB_Suspend () and USB_Reset(), then the ISR never seems to execute again.
"I do see the IUSB_SR firing on reset, it executes a USB_Suspend () and USB_Reset(), then the ISR never seems to execute again.
Your description is interpreted that no signaling comes from the host side, except for the very early one of the device connection.
Sound like the problem of D+ pull-up resistor (1.5k). Host side (PC root hub or external hub) detects the connection of the device seeing the voltage change of D+ line, caused by this resistor. As the host side doesn't detect the device connection, no signaling comes from the host.
Depending on your board, this resistor is, a) fixed one b) controlled by a port of the chip using a transistor (PNP or Pch FET)
a) fixed one Check the soldering of D+ pull-up resistor. Or check the voltage supply to this resistor.
b) controlled by a port Enable D+ pull-up resistor after finishing initialization of the USB SIE.
Tsuneo
Thanks, that was the first thing I suspected as well. Turns out the new board I was porting to has a different clock speed, once I adjust the clock registers all was well.
Thanks again.
If I may impose again, I just started seeing a problem when I happen to send USB packets of exactly 64 bytes. I am actually sending 4 separate packets of 64 bytes each from the device up to the host. (In between sends I wait for the USB ISR to set a flag that tells me the buffer has been read). The host seems to get this as 1 big packet of 256 bytes. I am looking at a USB packet sniffer (SourceUSB) and I see this 1 big packet sent over. As an experiment if I set the packet size to 63 or 65, I see 4 distinct packets being sent.
Do you send a zero-byte packet after the 64-byte packet, to tell the receiving side that 64 bytes really is the full amount of data?
I do not. Yes, this must be the problem, how else would the host know the entire response has been received. Thanks!
"As an experiment if I set the packet size to 63 or 65, I see 4 distinct packets being sent."
65 bytes packet is not fine, because its size exceeds wMaxPacketSize (= 64 bytes). "how else would the host know the entire response has been received."
As Per said, you have to send ZLP (Zero-Length Packet) to finish the transfer, when the last transaction (packet) is just 64 bytes. No other way.
Windows usbser.sys (CDC device driver) assigns 4K bytes of real memory for DMA to the host controller, to receive each bulk IN transfer. ie. 4K bytes is the expected transfer size. While the device sends full (64 bytes) packets, the host controller regards that the transfer continues, and hold the data on this 4K bytes buffer. When the device sends a short packet (less than 64 bytes, including ZLP), the host controller takes it the end of transfer, and it passes the entire transfer on the buffer to the device driver.
Short packet (including ZLP) cuts off the expected size of transfer. 4K bytes is the page memory size of PCI bus, max real memory size for single DMA session.
Not sending the 0 length packet was indeed the problem. By the way my last post was misleading, I never attempt to send more than 64 bytes, larger packets are first broken up to smaller (max 64 bytes) packets and sent individually.
Thanks again for your repsonse.
I have been trying to find a place to download the WdfCoInstaller01005.dll. Where did you find it? I couldn't find it rummaging through the MS site (and we even have the subscription). Thanks.
If I may I have another question. I would like my device to detect when the host connected and disconneted. Probably not just physically connected but rather when the commuication pipe has been establised or broken. If you recall I am using a modified verstion of the Keil mass storage driver, all our communication is done over BULK endpoints. I did experiment with this a bit by setting breakpoints in the USB ISR but I either could not find what I wanted or did not hita breakpoint when I thought I should. I do sometimes have trouble with breakponts being recognized when debugging some of the USB code, code I know that is executing. Any suggestions where how to detect pipe connection events?
"I have been trying to find a place to download the WdfCoInstaller01005.dll."
WdfCoInstaller01005.dll is included in the old release of WDK. But for new design, use the latest version. The number after "WdfCoInstaller" shows the version.
Thanks. Perhaps physical detection on connect/disonnect will suffice. These should be detectable events correct? I experimented with this in the past, setting breakpoints at the ISR and seeing what get executed when I physically connect and disconnect USB. This was sometimes problematic as it seems that Keil debugger has problems hitting breakpoinrs in ISR.
