Trying to transmit with interrupt in XC164CS
Hi everybody,
I am learning to program with MCUs and now i have got the SK-XC164 board.I am trying to transmit via ASC0 a message. This message has 6 equal bytes and I must do it with transmit interrupt. Has anyone a simple program to practise??. The message I would like to see the message through Hyperterminal on PC. Thanks to everyone.
  • I hope you are using the right vector to handle your communication? that would be required if you changed to ASC1.
  • How do I know if I am using the right handle?
    The ASC0 and ASC1 are supossed to be equal, aren't they?
    Thanks for reply.
  • well, look in your data sheet. I assume each of these peripherals has its own interrupt vector. you need to change the number of your interrupt service routine to handle ASC1 rather than ASC0.
  • There is a difference in what the pins share for the ASC1 concerning other features on the device. For example if you are debugging with JTAG then you have a problem since the JTAG pins are shared with the ASC1 port. So you cannot do both at the same time.
    So here are the pins...
    P3.1/T6OUT/RxD1/TCK
    P3.5/T4IN/TxD1/BRKOUT
    Keil doesn't use the BRKOUT feature so the TxD1 is ok to use for transmitting. However, you have a problem on the receive pin, TCK (JTAG Clock) being shared with the RxD1.
    -Chris
  • For Tamir:
    I have different vector for my interrupt service routine. Look this:
    #define ASC0_TINT    0x2A
    #define ASC0_RINT    0x2B
    #define ASC0_TBINT    0x47
    #define ASC1_TBINT    0x5E
    #define ASC1_RINT    0x49
    void ASC1_viRx(void) interrupt ASC1_RINT using RB_LEVEL15
    For Chris:
    I have already taken that into account. At this moment, I'm not using JTAG, therefore this Rx pin is free. Its my opinion :(
    Thanks.
  • did you make sure your ISRs have distinct priorities (group/level, if it is indeed the same as on a C166...)?
  •   ASC1_CON       =  0x0011;      // load ASC1 control register
      ASC1_BG        =  0x0011;      // load ASC1 baud rate time reload register
      ASC1_TXFCON    =  0x0100;      // load ASC1 transmit FIFO control register
      ASC1_RXFCON    =  0x0100;      // load ASC1 receive FIFO control register
      ALTSEL0P3     |=  0x0020;      // select alternate output function
      P3   |= 0x0020;    //set data register
      DP3  |= 0x0020;    //set direction register
      ///  Configuration of the used ASC1 Interrupts:
      ///  TxBuffer service request node configuration:
      ///  - TxBuffer interrupt priority level (ILVL) = 14
      ///  - TxBuffer interrupt group level (GLVL) = 1
      ///  - TxBuffer group priority extension (GPX) = 0
      ASC1_TBIC      =  0x0079;
      ///  Rx service request node configuration:
      ///  - Rx interrupt priority level (ILVL) = 15
      ///  - Rx interrupt group level (GLVL) = 1
      ///  - Rx group priority extension (GPX) = 0
      ASC1_RIC       =  0x007D;
      ASC1_CON      |=  0x8000;      // enable baud rate generator
  • Finally, the mistake was that the wire wasn't well connected. The program runs correctly.
    Thanks for your helps
