nid help on LED blinking
i have problem with the led blinking. I using the exmaple program given by keil using uVision3. When i run the program, the LED on the development board didnt blink, it just stay on! wat should i do?
thanks!
  • I have another question, how do I pass value from RFID to microcontroller? Do i need to use another port from microcontroller and connect it to RFID? or both RFID and microcontroller connect to the same computer?
  • Don't you think that your question requires a description of what type of interface the RFID has, and exactly how you have connected it?
  • "Do i need to use another port from microcontroller and connect it to RFID?"
    If you want to connect the RFID directly to the microcontroller then yes; of course you will need to use some sort of "port" on the microcontroller - exactly what sort of a port will, of course, depend upon what your particular RFID requires!
    "or both RFID and microcontroller connect to the same computer?"
    If that's what you want then yes; you can do that!
    It's your project - only you know the details of what's actually required.
  • "I have another question..."
    Before moving on to another question, have you actually got the LED working yet?
    Blinking an LED really is the most basic, foundational thing to do with a microcontroller - if you can't get that working, you are not ready to move on to anything else!
