Hi all
how can i interface DS1820 temperature sensor with 89s52 uC. So that it can display temp on LCD.
thanks in advance
aditya
"sneak away from the support costs"
I have seen a couple of embedded projects of the "sneaking away from the support costs" type.
The "promote a technology" kind seem to be quite unusual in the open source world. The code more often ends up as the "manufacturer code" we can download from the chip vendors. No interaction other than the normal: We may report bugs, and they may decide to ignore them.
sir i am using Keil demo version to compile my software is it ok with demo version.
i am using Keil demo version to compile my software is it ok with demo version. 1) what does this have to do with "Need help in interfacing of DS 1820 with 8051" 2) it is NOT OK if you are developing for commercial purposes 3) it is not OK if it does not fit withon the limitations of the demo version
sir i mean whether keil(demo ) is able to compile the software or not.
The Keil demo software can compile ANSI C code up to the limits of the version you have. There are some that will only work with a specific brand of chip. The generic one will generate code for any 8052 CPU, but is limited in size. A simple single chip 1-wire app should fit.
