Strange behaviour in TIMER0 ISR
Hi all, I have a problem with the ISR of TIMER0.
I'm using keil uVision2 and my target is SIlicon Laboratories C8051F040.
I've tried to make a very simple project in assembler to use Timer0 ISR (below you will find the relatives code) and it works fine.
If I try to translate this project in C, the ISR is called just a few time (around 10 or 11 times) but after this, it is never called!
But... if, instead of Timer0, I use Timer1, all work fine both in C and in Assembler
I can't understand why?
There is someone wich can help me?
NOTE: Is not important the reload value so i don't set it, and although if I set this value the behaviour not change.
NOTE: Timer0 is a 16-bit timer
NOTE: In the examples below I've hided the not relevant code like oscillator init, port init,...
ASSEMBLY CODE:
;TIMER_0 Overflow
ORG 0x000B
        LCALL TIMER0_INT
TIMER_INIT:
        NOP
;TIMER0
;TIMER1
        MOV SFRPAGE, #TIMER01_PAGE
        MOV TCON, #01000101b
        MOV TMOD, #00100001b
INTERRUPTS_INIT:
        MOV IE, #10010111b
        MOV IP, #00000000b
        MOV EIE1, #00001000b
        MOV EIE2, #01000000b
        MOV EIP1, #00001000b
        MOV EIP2, #00000000b
MAIN:
        MOV SFRPAGE, TIMER01_PAGE
        SETB TR0                        ;START TIMER
        JMP $
TIMER0_INT:
        RETI
C CODE:
void Timer_Init() { SFRPAGE = TIMER01_PAGE; TCON = 0x45; TMOD = 0x21; CKCON = 0x18; SFRPAGE = TMR2_PAGE; TMR2CN = 0x04; TMR2CF = 0x08; SFRPAGE = TMR3_PAGE; TMR3CN = 0x04; TMR3CF = 0x08; SFRPAGE = TMR4_PAGE; TMR4CN = 0x04; TMR4CF = 0x08; }
void Interrupts_Init() { IE = 0x97; EIE1 = 0x08; EIE2 = 0x40; EIP1 = 0x08; }
void main(void){
Timer_Init(); Interrupts_Init() ... ... ...
SFRPAGE = TIMER01_PAGE; TR0 = 1; //START TIMER
while(1);
void timer0_int(void) reentrant interrupt 1 {
  • Maurizio,
    Here's something to try: In your C code, disable all the interrupts aside from the one you're checking. For instance, I notice that you're setting both external interrupt sources to enabled. Your C code (or your assembly for that matter) has no handler for these interrupts. If one of those signals toggles, each bit of code will do something that you haven't defined. It could just be that the layout of the C code causes this flaw to be more evident whereas your assembly code eventually gets back to main and continues executing like nothing ever happened.
    -Jay Daniel
