How to resolve the contention between 2 ADC0801!!!???
I would like using two ADC0801 in order to read 2 Vol electric signal ., 2 ADC interfaces with AT89c51 by using common input..If I use an ADC, no problem, but with 2 ADC ,ADC will not working!!!! Please help me!!!
My programmer and file Proteus is below
www.MegaShare.com/512261
In my progam: i use 2 button to control 2 ADC.each ADC have each pin INTR to connect 2 separate input pin of the processor..so why d'ont INTR pin of ADC work,after converted...this thing cause ADC can't be read by processor
Problem with an interrupt signal only affects how you will know that a conversion is done - it does not affect your ability to talk with the ADC.
when I remove ADC2 in my circuit(proteus),ADC1,processor run as normal When i remove ADC1,then ADC2 also does not work...Why??There is only ADC1 work actually if all 2 ADC connect in circuit,When I press any buttons,,chip does not work...see here.www.mediafire.com/
"Problem with an interrupt signal only affects how you will know that a conversion is done - it does not affect your ability to talk with the ADC"
i understand this thing.My mean:i use button to allow operate ADC,star convert,,then wait signal INTR from ADC send to CHIp to alert "finish start convert",after chip will read ADC then show in leg7seg...is this right??
my code use for operating ADC
if(button1==1){ CS_1=0; WR_1=0; WR_1=1; while (INTR_1==1);//wait for signal INRT_1...cho den khi co tin hieu ngat tu ADC CS_1=0; RD_1=0; //CS_1=1 not write here khong the dat o day...dan toi ko doc duoc }
... you need to post them in a format people can read.
Unfortunately, as far as I know, there is no universal schematic format - so you will have to export it to something like GIF or PDF.
Note that JPEG is not (generally) a good choice for schematics...
"When i remove ADC1,then ADC2 also does not work...Why??"
That's for you to find out!
You have the hardware there - what investigations have you done?
Do you have an oscilloscope?
"You have the hardware there - what investigations have you done?" i d'ont have hardware, i have just only stimulate my circuit with Software proteus 7.2,and program with keil c,
"Unfortunately, as far as I know, there is no universal schematic format - so you will have to export it to something like GIF or PDF."
i imported my circuit to file format bitmap..,first ,start testing my circuit here....www.mediafire.com/
alert me when link die!!!!
In that case, use whatever facilities your simulator provides as it's simulated equivalent of probing with an Oscilloscope.
For help in how to use your simulator, you're going to have to go to their site - it's not a Keil product. Do they have a forum?
i have already debuged my code C with Keil,run as normal,but it can't stimulate with PROTEUS, ,so i will write my code here,,help me to test my code please!!
this program use each button to read each ADC //button1=P2_6 //button2=P2_7
#include <REGX51.H> sbit ledD0=P0^0; sbit ledD1=P0^1; sbit ledD2=P0^2; sbit ledD3=P0^3; sbit ledD4=P0^4; sbit ledD5=P0^5; sbit ledD6=P0^6; sbit LED_0=P2^0; //hang don vi sbit LED_1=P2^1; //hang chuc sbit LED_2=P2^2; //hang tram sbit INTR_1=P3^2;//INTR0 of CHIP sbit INTR_2=P3^3;//INTR1 of CHIP sbit CS_1=P3^4; sbit CS_2=P3^5; long n; int a,b,c; void delay(long time) { for(n=0; n<time; n++) { ; } } void bit_dec() { c=P1%10;//hang don vi b=((P1-c)/10)%10;//hang chuc a=((((P1-c)/10)-b)/10)%10; //hang tram } unsigned char x; void Hienthiled(x) // Co 1 bien dau vao de xac dinh xem la hien thi so nao { int arr[]={64,121,36,48,25,18,2,120,0,16} ; P0 = arr[x]; } void inhangtram() { LED_2=0; LED_1=LED_0=1; Hienthiled(a); } void inhangchuc() { LED_1=0; LED_0=LED_2=1; Hienthiled(b); } void inhangdonvi() { LED_0=0; LED_1=LED_2=1; Hienthiled(c); } void laymauADC1() { //convert voi ADC1 CS_1=0; //Make CS low RD=1; WR=0; WR=1; CS_1=1; while(INTR_1==1); //Read ADC CS_1=0; //Make CS low RD = 0; //Make RD low RD = 1; //Make RD high CS_1=1; //Make CS high } void laymauADC2() { //convert voi ADC2 CS_2=0; //Make CS low RD=1; WR=0; WR=1; CS_2=1; while(INTR_2==1); //Read ADC CS_2=0; //Make CS low RD = 0; //Make RD low RD = 1; //Make RD high CS_2=1; //Make CS high } void phimbam() { if(P2_6==0){laymauADC1();} else if(P2_7==0){laymauADC2();} } void main(void) { while(1) { WR=1;// chuyen doi lai RD=1;// xoa gia tri da doc truoc do phimbam(); bit_dec(); inhangtram(); delay(3000); inhangchuc(); delay(3000); inhangdonvi(); delay(3000); } }
if you want to see schema you can see here www.mediafire.com/
Please read the instructions on how to post source code - they are really quite clearly stated: www.danlhenry.com/.../keil_code.png
Note that TABs don't work (well) - use spaces instead,
and don't forget to check it in the 'Preview'...
If you can miss such obvious details when just posting on a forum, you're going to have reall difficulties with embedded development...
wow! cool! remarks in mandarin (I think) !
