Serial interrupt behaviour?
Hi everyone!
I'm a n00b to microcontroller programming so have patience with me :)
The mission is to handle some uart (rs232) communication, both rx and tx. My part is a small module going into a rest of the software already developed.
The issue is the following: When I use serial ISR it seems to not go into the "main while loop" (which is required).
(I've also tried to poll my self but reliability seems somewhat unstable, loosing a byte here and there)
I've tried the simplest demo/test programs and if I for instance use a printf in the while loop, it will not reach it as soon as ES = 1.
Is it just that any printf will not issue an interrupt and hence no output to my terminal? At the moment I can not test my module with the rest of the software so I'm a bit in the blind here, well could of course try to blink a led or something... but I reacon a answer from here is faster and more reliable :)
Thanks in advance
/Mike
