i m interfacing the stepper motor with 8051 i hav all circuitry ready but i want to know how to generate the required RPM for stepper motor EG: i want to run my motor at 60 RPM then what all calculations are required i hav taken a timer for the clock pulses but confused in the calculations do u hav any sample program for it i m using ic which has clocks pulse pin, i will be giving the clocks to that pin
i nned simulator of motor in code for important projekt so i need code,,,,, you undesratand me??????
This is the first time you so much as mentioned anything about simulation. How were people supposed to understand what you didn't bother to say? Mind-reading doesn't work all that well across the internet.
You're finally beginning to make a little bit of sense --- but you still haven't shown the slightest hint of initiative from your end. It still looks like you're not looking for help, but for somebody to do your entire work for you.
Have you read any of the materials that have been pointed out to you?
send me the code you have got to halop_relkarv157@hotmail.com
here is my email address
I still not get it
the email is halop_relkarv157@hotmail.com
send for me to use quick
help me very soon or i run out of time to do work
And how angry will your teacher be then?
Do you send similar mails/letters to Santa every christmas too?
why you say teacher??????????????????
it my boss who wants projet tomoroww
i running out of time, send files now
Not school work? But if it is commercial work - how much money where you planning on sharing with the people you want to get the source code from? Is it a fifty-fifty split or?
we help each perosn,,, i help you and advise when you need help in later time,,, we are brotehrhoods of devlelopers
so send code you have now??????????????
"send code you have now"
Code for what?
You haven't given any indications whatsoever of what type of stepper motor you're using - let alone specifics of make and model; You haven't given any indications whatsoever of what processor you're using; haven't given any indications whatsoever of how the stepper motor is connected to the processor; You haven't confirmed that you're using Keil tools...
etc, etc, etc,...
With such an almost total lack of specification, anything sent could only ever be extremely generic - which, surely, you must already be able to find on the internet?!
if you dontt give me help you dont ask me for help when you need it!!!!!!!!!!!!!!!!!!!!!!!!!
If you can't give an adequate specification (or, in fact, any specification at all) of what you require, how can anyone help you?!
As already noted, Mind-reading doesn't work well across the internet!
i sayed what i need,,, i need simulator of motor in code
why you think it is dificullt?????
have yo ugot code or pretend to anoy me
What part do you not understand?
Simulation of what type of motor.
Motor simulator behaving how? Graphical front-end showing a rotor stepping? LCD display showing current step? Other alternative?
Simulator interfacing how with microprocessor? Or simulator interfacing with the uVision IDE using DLL interface? Other interface?
In short, you have not sayed [sic] anything about what you would like. However, you have implied that you want a magic fix for an unknown problem that you work very hard with, and that your boss expects you (since there is no budget for sub-contractors) to solve during the past weekend.
But then again, if you don't think it is difficult - why don't you just write the code? Especially since you must know exactly what it is you are looking for.
halop,
Instead of 'working so hard', you should occasionally take a break and check your email account.
I sent you a motor simulator that I wrote yesterday. Don't know if it is what you want (I don't think YOU know what you want), but it was a genuine attempt to help.
It got bounced back with 'mailbox unavailable'!
...the demand for free work, or the assmption that anything useful could be provided with such a total lack of any meaningful specification!
:-0
