Hi dazheng,
Need to know ... what is EEPROM used in MCU for ?. I know EEPROM stand for Electrical Erasable Programming ROM but I need to know what's the purpose or where it going to be used in MCU?
I ask this because some of MCU dont have EEPROM ( EEPROM = 0 byte) ie 80NC535 & 80NC321 and the best thing about this MCU (without EEPROM) that's its cheaper than MCU with EEPROM. If it just minor used and can solve it in other method (and not effect my project) , I will use it as I need to lower the cost as much as possible.
Any instruction (ie in proton) that must be used on MCU with EEPROM ?
More explanation greatly appreciated.
zuisti
"Is that a statement or a question?"
For your reference, that's a question.
And for your further reference, that's a statement.
"By the terms 'load labeL', 'solar panel label', 'batt label' , i mean 'load current', 'solar panel current' and 'battery voltage'"
Yes, that's a great idea - let's just choose some random word like 'label' and use it to mean 'voltage' or 'current' at random.
Why don't you just call eveything "Bruce" to avoid confusion?!
Hi "zuisti",
thanks MatE,
briliant article that.i've been wriing me own ones recentkly and hope to put on a website like that; maybe with results of some of our the other work yeah?
fame man! maybe the trollops around here will learn from you're quality investegations.
last problem you know this; I think you are asking for the code which are contained in a matrix form all the dots for a character. I've seen som examples from the web with this codification, I dont know what are you programming ATM, but the codification its universal, keep looking good luck
thanks agaiin for the article. you remember it for the good future yea !
"With errors occurring in the very first code snippet in Chapter 1, I didn't even bother to read further."
Its description of the terms lvalue and rvalue is also somewhat askew...
"briliant article that."
Yeah brilliant, mistakes and all. Let's all learn to write bad code. You two are already experts at writing crappy code.
"i've been wriing me own ones recentkly ..."
Oh, please spare us. There's already too much crappy code on the web. Thanks anyway.
"... the trollops around here ..."
Your sister? Where, WHERE!? I am mighty curious to this bushy maiden. Is the circus in town?
"Its description of the terms lvalue and rvalue is also somewhat askew."
Indeed, yet "brilliant" in the eyes of at least one of the nitwits.
I think that's not true with the solar labal buttorn . If you assume the digital pot is connected to a reference voltage with the MCU and GND and gives a voltage at the middle contacts, your calculation might be right, but it depends on how the circit is designed and works? The pot can be part of a RCL time giving circuit, it might float(?) over ground or lie in the loopback of an digital mru OPamp, therefor you cannot simply assume a GND referenced DC voltage of level 'A' will make the servo move right and a voltage of level 'B' will make it move left. If it is an seudo analog circuit it is probably that you shortcut (disable) the RC timer by pulling the middle and upper connector to GND with R12 and C15, the time constents of the circuit will be reduced to the lowest value possible and that makes your servo move in one direction only - but as result of an error not as a result of applying the right voltage level.
You need to further analize the circuit to understand what the right solution might be. Replacing the pots with digital types in any way should work but isn't cheap all.
"float(?)"
Correct. A green star for you!
When you doubt how a word is spelled, look it up in the dictionary. Don't ask here.
Hi zuisti,
Im too interested in forgeting the first project now bcoz it is to easy and building the second project in the list, I am thinking about:
what mpuC to use? i think one with big speed will bee needed for ADC and movement?
is a single mpu enough to control all the axes orf movement. one for each is better.we can finish project qwikly if we get get one person to write code for each and.
No decision made yet so plz help me(?) for the best work.
trolops are v mean about my sister. plz dont mention her again here.she is not happy with meye
your business friend,
dazheng
ach, and you know my sister is NOT very hairy.
When handling many axes, it is extremely important that the controlling chip is intelligent enough - a runaway axe can generate a lot of damage in a short time!
I would recommend the use of either a Itanium 2, one of the more recent PA-RISC processors or possibly an Opteron solution.
and just who do you think is doing the butting-in, then?!
Are you finally coming to realise that this is not the place to carry on your private conversation?!
Once you fully realise this, perhaps you will go away to a more appropriate place for your inane babblings.
Please.
"Im too interested in forgeting the first project now bcoz it is to easy and building the second project in the list"
Yes - what's the point in finishing one project before you start the next?!
"plz dont mention her again here"
You shouldn't have mentioned her in the first place!
Particularly not here!!
"she is not happy with me"
I'm not surprised!
"is a single mpu enough to control all the axes orf movement."
Is that a question or a statement?
Anyway, a simple, but strong MPU is needed. Orf axes are quite heavy. The ones I've seen wielded are at least 50 pounds, but not a problem for big strong Orfs.
"she is not happy with meye"
I'll bet, what with you suggesting her fur was plugging up the shower and all.
"and you know my sister is NOT very hairy."
Just 'a little chubby' then, I guess. Remember you said:
"if she goes backward the water is suck up shower"
So, she's so huge that backing out of the shower creates that much suction! She must be quite the vision of loveliness. (Shudder)
She probably was hairy until she got caught in the shower. Alas, it will grow out again in a short time.
By the way, I am really, really worried about those axes, unless they are mounted in a single-axis jig for chopping wood. A multi-axis multi-axe battle-axe setup would be seriously dangerous in case the watch dog doesn't perform his job and keeps the guard awake.
