Hi All,
I managed to update my FW, but the new FW is not start to work.
I checked that the new FW is burn correctly (I verify it with uVision3 with the verify option at the utility settings).
Please advice Kobi
Hi Kobi,
Thanks again.
I have a little confuse. I'd checked the address 0x14, it should be and interrupt vector (VicVectAddr) in my startup.s, like below.
//Startup.s Vectors LDR PC, Reset_Addr LDR PC, Undef_Addr LDR PC, SWI_Addr LDR PC, PAbt_Addr LDR PC, DAbt_Addr NOP ; Reserved Vector ; LDR PC, IRQ_Addr LDR PC, [PC, #-0x0FF0] ; Vector from VicVectAddr ////////
I know how to write flash by IAP function. Actually, I don't know how to write a program to update entire flash, so I separate my image to two regions. And hope the boot region is fixed (but not). I found the problem might happen in __user_initial_stackheap() or __user_setup_stackheap(). Because KEIL will add them if I don't override them. Similar, if my application use the new function that need C library. KEIL compiler will increase the C library into my boot region since my scatter.
However, if I can know how to re-write the entire flash in runtime, I don't need to care the KEIL compiler did. Can you show me how?
Best Regards, Dennis.
Hi Dennis,
In order to update all the FLASH you need to run your IAP functions from the RAM.
After you receive you new FW image, and you decide to burn it, your application should run a routine from the RAM that will erase all the FLASH and will burn the new one instead of it. Obviously you should save the new FW at external FLASH or save it at the upper addresses of you controller and therefore erase only half of the controller.
In my case, I received the new image to external FLASH, then parse it and copy it to the upper controller addresses and as soon as the new FW is at the controller, I run routine from the RAM in order to copy it from the upper addresses to the lower one. This architecture can be more efficient (copy it from the external FLASH directly to the lower controller addresses) but the first one requires less code in the RAM.
In addition you have to add the checksum to the new image at address 0x14. The old ISP application of NXP add the checksum to the code.
Regards Kobi
