Hi, I have an address on the APB which has a READ functionality and a WRITE functionality. If I read from it I get the status, and when I write to it, I set something else (Has nothing to do with the status).
I declared this address using a variable which is located using the _at_ keyword, and I get the "L30 memory space overflow" warning. Now I understand the warning is OK, but I wanted to know if there's a way to remove it for these specific addresses (I don't want to disable L30 entirely), or maybe uVision supports this specific issue somehow...
Thanks..
"but I still don't see the need to specifically insist that it must be an assembler routine."
I'm not so much saying that this is specifically insisted, rather I feel it is something that tends to naturally lend itself to this approach.
For example, the bit twiddling to which I previously mentioned is something that I normally find far easier to do in assembler. I never need to then concern myself with the efficiencies (or lack of) that the C compiler might carry out when doing such things as rotations and maskings.
In a low level driver, these operations are commonly hardware dependant and frequently go together with the hardware access - So putting them all together into a single assembler module assists the overall project layout.
"I would apply the same rule to these routines as to the rest of the code - do it in 'C' unless assembler is specifically necessary."
To me, one of the most important points in a project is the consistency. If different rules are used by different (or even worse, the same) programmers within a project then trouble normally follows. I have witnessed and had to recover such projects in the past!
So I may not necessarily agree with your rule, but I cannot fault the consistency.
We can agree on that one!
