How to interface GSM module to a microcontroller?
Dear Andy,
I am new here and I have some questions to ask you about. I have just started with my school project (bus tracking system). My part in this project is to interface GSM using a microcontroller and to a computer (receiver part). I have some ideas but not good enough. This thread will be a part of my research. Could you please give me some basic ideas how about to do this?
  • "I am new here"
    Before posting to any new forum, you should take care to understand the purpose of the forum - and ensure that your post is "On-Topic"
    The purpose of this forum is stated here:
    http://www.keil.com/forum/
    http://www.keil.com/forum/terms.asp
    It is specifically for discussion about Keil tools - it is not for personal messages to individuals.
    "This thread will be a part of my research."
    For "research" start by using the 'Search' facility - there have been several recent threads that will give you the basics
  • Well, I am actually searching for device/devices which I can implement it to my GSM module, (such as a microcontroller) to a PC. One thing in my head is to use a ATMEL microcontroller. However, I want to find out if there are any other devices I can used? My question is, not how to implement it but which product Keil can offer me to use?
  • Have you looked at Wavecom: their devices allow you to write 'C' firmware within the module - so no external microcontroller is required.
    http://www.wavecom.com/OpenAT
    Other manufacturers also have various options for scripting within the module...
    "One thing in my head is to use a ATMEL microcontroller."
    That's a bit like saying, "I'm thinking of using a Ford car" - Ford makes a whole range of cars!
    Atmel make (at least) three different families of microcontrollers: 8051, ARM, and AVR. Which did you have in mind?
    "I want to find out if there are any other devices I can used?"
    See above - do you even need a separate microcontroller at all?
    Interfacing to a modem (any modem, not just GSM) is really just a serial comms project - just about any microcontroller could do it (GPRS is more complex, as it requires TCP/IP).
    "which product Keil can offer me to use?"
    It should not surprise you to find that this information is on the 'Products' page!
    http://www.keil.com/product/
    Again, this has nothing to do with software development tools - any compiler from any vendor will do.
    First, you need to decide which microcontroller family (if any) you will use - then you can look for tools which support that family!
