DEAR TO ALL, I AM DEALING WITH C8051F120 MICROCONTROLLER.UTILIZING 16 X 16 MAC ENGINE OPERATION.I AM DOING ASSEMBLY LANGUAGE PROGRAMMING USING THIS MICROCONTROLLER FOR MULTIPLICATION. IS IT POSSIBLE TO MULTIPLY TWO UNSIGNED 16 BIT INPUTS? IF YES, THEN HOW ?
"But how can we tell whether the inputs msb bit is set or not" why 'tell', shift ALL inputs one right, if you do not shift ALL inputs, you will have a true mess.
I answered your first SHOUT because you might be SHOUTING being unaware of the implications (rude and difficult to read), but when you start SHOUTING again (as below) after being asked to stop, I see no reason to help you if you persist.
No, SHOUTING people who also thinks their problems are more urgent than other peoples should expect their problems to receive a minimum of interest.
hi Mr.Christoph Franck and others, thank you for your reply.what is the use of MAC0RS bit in C8051f120
I searched about that bit pdf files,but in vane can you help me?
"I searched about that bit pdf files,but in vane"
Really?
What about page 170?
www.silabs.com/.../C8051F12x-13x.pdf
The chips datasheet states, on page 162:
When set to 1, the 40-bit MAC0 Accumulator register will be shifted during the next SYSCLK cycle. The direction of the shift (left or right) is controlled by the MAC0RS bit. This bit is cleared to ‘0’ by hardware when the shift is complete.
Setting this bit to 1 therefore instructs the MAC engine to do a 1-bit bitshift on the accumulator of the MAC engine. The direction of this shift can be controlled with another bit in the same register.
MAC0SC: Accumulator Shift Control.
After reading this section i searched for MAC0RS bit in the include files,for getting more about this bit.
do you know which register contain this bit? help me please
Mr.Christoph Franck, first of all i am thanking you for giving immediate response. now discussion:
After reading the part you pointed out,i got confused that whether MAC0SC and MAC0RS are equal because no where i saw any further description about that bit.
may i interrupt you asking other question?
if yes my question is:
ACALL and LCALL how we utilize in program?
because i have to reduce execution time
guide me for this question : how many ways we can reduce code size
MAC0SD and MAC0RS seem to refer to the same bit (the one that controls the direction of the bit-shifts). MAC0SC is the bit that actually triggers the bit shift.
You can use ACALL to call a subroutine within the same 2 kB page of the code memory. Else you have to use LCALL. ACALL and LCALL take the same number of processor cycles, but ACALL only takes two bytes, while LCALL takes three.
ACALL and LCALL have the same execution time.
That is a question that's usually treated in large books. Especially since you also say that you need to reduce the execution time, too - quite often, you need to make a tradeoff between code size and execution time.
You can unroll loops, which makes the program faster, but larger, for example.
You can use macros instead of function calls, which also makes the program faster, but larger.
You can calculate any math functions you need, or you can use lookup tables. The former usually leads to slow, but small code, while the latter takes up a lot of space, but can be very fast.
You are right - the Datasheet says what the MAC0RS bit does, but omits to tell you where it is!
But that is a fault in the SiLabs Datasheet - it has nothing to do with Keil. Therefore you should direct this question to SiLabs!
"ACALL and LCALL how we utilize in program?"
Sounds like you need a basic 8051 assembler tutorial, then?
Have you read Chapter 2 of the so-called "bible" for the 8051?
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
Here are some other introductory & reference materials: http://www.keil.com/books/8051books.asp www.8052.com/books.phtml www.8052.com/tutorial.phtml
"That is a question that's usually treated in large books."
It is a common fallacy that the mere act of writing in assembler will inherently give you fast, tight code.
This is simply not true: it takes a great deal of skill and experience to write fast, tight code in any language! Sure, assembler gives you more opportunities - but you need to know how to use them!
If you need to ask basic questions like how to use ACALL and LCALL, you're probably not quite ready to be turning out super-optimised code...
You might even find that the compiler can do a better job - especially with optimisations enabled (but then that gives you the issues with debugging - which comes back to skill & experience)
from the datasheet: Bit 5: MAC0SC: Accumulator Shift Control. When set to 1, the 40-bit MAC0 Accumulator register will be shifted during the next SYSCLK cycle. The direction of the shift (left or right) is controlled by the MAC0RS bit. This bit is cleared to ‘0’ by hardware when the shift is complete. Bit 4: MAC0SD: Accumulator Shift Direction. This bit controls the direction of the accumulator shift activated by the MAC0SC bit. 0: MAC0 Accumulator will be shifted left. 1: MAC0 Accumulator will be shifted right.
It should be obvious that MAC0RS and MAC0SD is the same as mentioned in a former post.
"It should be obvious that MAC0RS and MAC0SD is the same as mentioned in a former post."
Maybe so, but it's clearly an error in the datasheet.
Of course, the SiLabs datasheet has nothing to do with Keil - this needs to be taken up with SiLabs!
this needs to be taken up with SiLabs! I already did
hello to all , i am using keil uvision3 and device selected is c8051f120.after execution of the project, the states is 1992 and execution time is 0.000650 seconds Note:clock is 50MHz
please tell me whether i forgot any step missed or is it correct ?
if my answer is correct,then what is the relation between states and executed time?
i calculated like this
(1/(50*1000000))*1992=39 microseconds
but answer i got is .6 milliseconds
why?
please i need your help
sory for interrupting you all
Regards Ranjini.NP
please reply to this
