Intterupt not working...
I'm using a timer and external interrupt to detect the pulse, i can set the timer to run for 5 secs and loop back. But the program cannot vector to the external interrupt. This is my interrupt configurations and routine.
;-----------INTERRUPTS CONFIGURATIONS--------
MOV IE,#8CH
MOV SWCINT,#000H
MOV EIE1,#000H
MOV EIE2,#000H
MOV EIP1,#000H
MOV EIP2,#000H
MOV IP,#08H
;-Timer 1 Overflow Interrupt-
T1_INT:    CLR TF1        ; Clear overflow flag
          MOV TH1,#0D0H
          MOV TL1,#0A0H
          RETI
;-External Interrupt 1-
EX_INT:    INC 40H         ; Increment 40H
          RETI
Does the input to the external interrupt need to be digital? Any advice would be nice... Thanks in advance.
  • What is X measurements?
    X is a positive number which is larger than 1.
    So if X is 4, you take four beat-to-beat measurements and average them.
  • "4 beat-to-beat measurements"
    You mean like from one pulse to 1 pulse, that is considerd one beat-to-beat? If i take 4 beat-to-beat, won't that a very long time?
  • The concept is called a running average.
    You use the time between beat 5 and 1 (4 periods) to emit a bmp.
    Then you use the time between beat 6 and 2 (4 periods) to emit a bmp.
    Then you use the time between beat 7 and 3 (4 periods) to emit a bmp.
    The first output will not be available until after you have detected 5 heart beats. Then, the display may update for every new heart beat detected.
    However, since a normal person at the best has a rest pulse just under 30 and normally in the 50-70 bpm, you can ignore the concept of a running average.
    If you take the time between 5 beats, a pulse of 28 bmp would give the first result after 9-11 seconds and then a new value every 9 seconds.
    With a more normal pulse of 60, the first value would be available afer 4-5 seconds, with a new update every 4 seconds.
    A young person at very hard load would with a pulse of 200 get a first value after 1.2-1.5 seconds, and a new update every 1.2 seconds.
  • I see... Many thanks for your all help...
    Regards,
    natur3
