I am trying to interface Flash AT29C512 with AT89C51 How do read and write serially between the 8 bit 8051 and 24 bit Flash,
Kindly help if some one has worked on this.
"Why should we not write to ACC directly in 'C'?"
You should not do it in any high-level language!
Because, when you use a high-level language (eg, 'C'), you delegate control of the low-level CPU registers to the compiler.
See: http://www.keil.com/forum/docs/thread8360.asp
"To call recursively, I believe it should be declared as 'reentrant'"
Even that won't help you if you call it recursively in an infinite loop!
I still recomend that you start with the "Hello World" sample.
The whole process of creating, building, and running the "Hello World" sample is explained in the Getting Started Guide. You should read and follow this - it will give you a proper introductions to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep-end!
http://www.keil.com/support/man/docs/uv3/uv3_creating_apps.htm
Then how come Rx() function works, and could you tell me why do we add 48?
I mean, to be called recursively it ought to be declared as reentrant, else no difference na
try checking status of ti and ri before getting into loop
Just following your advice, Hello World Hope am not testing your patience Sir, kindly explain this, In the program, Rx() where we write to ACC works, but Tx() where we read from ACC does not work,
ACC is defined in REG51.h, then should not we write to ACC?
Thank you Sir, the links were very helpful, specially for send byte You explained quite patiently, Thanks again for taking time out,
Thanks for all the help That little devil was in the while loop Tx(){ SBUF = ACC; while(TI){} TI = 0 }
Surely learnt a lot hunting it down, Thanks again
